Easy Security – Now to UNDELETE a user/login
  • Easy Security – Now to UNDELETE a user/login
    Posted by Lewis Rosenberg on October 2, 2017 at 2:29 pm
      October 2, 2017 at 2:29 PM
      ?Using Easy Security, the process to delete a user is to delete the USER record in your live NAV Company and then from the Easy Security company run Publish Permissions to synchronize Easy Security with the live company.Ā  The Easy Security Login Record then gets a check mark in the “Deleted Live Login” field.
      Is there a standard practice to reverse this since the “Deleted Live Login” field is read-only?
      I suppose I can permanently delete the Easy Security Login record and then add the user back.Ā  Is there another way to accomplish this?
      (We’re running NAV2013R2 and Easy Security 1.41.21)
      (Hmmm…what happened to the NAVUG.com tags?)
      NAVUG Programming Committee
      NAVUG Membership Committee
    • Greg Zavela
      October 3, 2017 at 8:29 AM
      Hello Lewis,
      If you wish to add the user back in you should be able to add them back to NAV security, then Publish Permissions in the Easy Security company.
      It is not specifically spelled out in the link below, but it is mentioned that this design (deleting a user in NAV security, but not in Easy Security) is to maintain the setup in case of accidental deletion.
      How to Delete Logins
      Let me know if this works for you.
      Greg Zavela
      Columbus
      Norwell MA
      October 3, 2017 at 9:08 AM
      ?That actually did not work, which is why I posted.Ā  Deleting the Easy Security Login record and then adding the user back did work.Ā
      My first thought was that if there was a way to uncheck the “Deleted Live Login” checkbox, then the user record could be recreated with all of its original permissions when publishing. That checkbox field is red-only, however.
    • Per Mogensen
      October 3, 2017 at 9:43 AM
      The reason it did not work is the Login have a reference to the internal ID “User Security ID”, when re-creating a User is a different “User Seciruty ID” created.Ā
      If you want to recreate the User follow the steps below.
      1: Export the Login from Easy Security.
      2: Delete the Login from Easy Security.
      3: Create the User in the standard NAV table.
      4: Use the function “Get New Logins”
      5: Import the Access Control to the Login created with the new “User Security ID”
      Per Mogensen
      President
      Mergetool.com
      Box Elder SD
      October 3, 2017 at 11:28 AM
      ?Thanks Per…that certainly explains the trouble I initially had when I simply added the user back in NAV and kept getting errors trying to publish all permissions.
      See you next week In Nashville!
    Lewis Rosenberg replied 7 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Easy Security – Now to UNDELETE a user/login’ is closed to new replies.
