E-Ship – UPS Manifest Label Print Problem – new work station
Posted by John Bellinger on December 12, 2016 at 10:53 am-
I’ve logged a support ticket with my solution center, but as they are not always prompt I thought I would post here and see if anyone else has seen this before. We setup a new E-Ship workstation, with a new Zebra printer. Printing UPS and FEDEX shipping labels works fine. However, when we try to print the UPS manifest label we only get the top 1/3 section to print and then the printer stops and the printer status indicator light turns red.
The Packing Station is set to Label Printing = Printer Name. In the Carrier I’ve tried UPS Label Printer Type of Eltron Orion and Zebra with same results.
Suggestions?
John Bellinger
ERP Manager
Activar, Inc.
Bloomington MN
Kris Ruyeras
MemberDecember 12, 2016 at 12:12 PM
Hello John,
Does NAV throw out an error? If not, I would check the Event Viewer to see if it shows up anything on there is where I would start.
Another area where I think you’ve already looked into is the setup card for another workstation that is working but it may sound like you’ve copied the settings over, it’s just the new printer that isn’t working.
Kristoffer Ruyeras
Bellegrove Medical Supply
Redmond, WA
NAV does not throw an error message.
John Bellinger
ERP Manager
Activar, Inc.
Bloomington MN
Marguerite Manelski
MemberDecember 13, 2016 at 7:49 AM
Have you checked your Packing Station settings? I would check there under the Label and Posting tab and make sure that the Print Shipment Report on Close box is checked off.
Marguerite Manelski
American Ring
Solon OH
We have the same issue. Rather than fix the problem, our partner made new labels using the E-ship label designer and then copied the code necessary to make it work. Not exactly what we wanted, but it is working.
Gregory Alford
ERP Manager
Tri Star Metals LLC
Carol Stream IL
Dave Cintron
MemberJanuary 11, 2017 at 6:52 PM
I’m a little behind on these NAVUG posts – did this ever get resolved? I’m thinking the size is wrong on the label.——————————
Dave Cintron
Dynamics West
Ventura CA
Dave, thanks for following up. In the end, we decided that the printer was bad. After it was replaced, all worked as expected.
John Bellinger
ERP Manager
Activar, Inc.
Bloomington MN
John Bellinger replied 9 years, 3 months ago 1 Member · 0 Replies -
The discussion ‘E-Ship – UPS Manifest Label Print Problem – new work station’ is closed to new replies.
