Delete Table that is “LinkedObject”
  • Delete Table that is “LinkedObject”
    Posted by genns@technicalprospects.com on December 23, 2020 at 1:01 pm
    • Greg Enns
      December 23, 2020 at 1:01 PM
      I’m trying to clean up old tables that we don’t use anymore and re-use them. (BC14 On-Prem)
      We have a couple tables that are based on SQL views, so they are a “LinkedObject”.
      I can delete them and the database synchronization works great. But when I try to create a new object in its’ place, the database synch still seems to think the old table existed and is now being deleted–but even a “Force” doesn’t work.
      I found this Mibuso post that is essentially the same issue. The solution there was to use some kind of “Database Check Tool” to sync a Metadata Snapshot. I have searched and cannot figure out what that means–or if that tool still exists.
      Has anyone found a way around this issue or any suggestions as to what the tool above is all about?
      Greg Enns
      ERP Coordinator
      Technical Prospects
      Appleton WI
    • Greg Enns
      January 11, 2021 at 10:07 AM
      Anyone have ideas on how to delete and re-use a table that was linked to a SQL view?
      Greg Enns
      ERP Coordinator
      Technical Prospects
      Appleton WI
    genns@technicalprospects.com replied 5 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Delete Table that is “LinkedObject”’ is closed to new replies.
