Customize a report
  • Customize a report
    Posted by Unknown Member on August 22, 2018 at 11:52 am
    • Laurie Gooch
      August 22, 2018 at 11:52 AM
      I was wondering if anyone has the steps to customize a report from NAV using word.
      Thank you
      Laurie
      Laurie Gooch
      Accounting Coordinator
      Creative Food Ingredients
      Perry NY
    • Ronald McVicar
      August 22, 2018 at 5:16 PM
      First, what version of NAV and do you have the right version of Microsoft Office (Word) installed.
      next: Does the report already exist and is there a custom report layout for Word or just RDLC. If just RDLC then you need to create a new report using an existing layout or copy an existing report. Ā
      This is a good link for a basic overview:
      How to customize an existing layout:
      HOW DO I – Customize Report Word Layout.
      Dynamics remove preview
      Hi Readers, This article is based on an email request that I received on my blog Contact form. The Request…
      View this on Dynamics >
      Or if a RDLC but you want Word layout follow this URL
      Create Word Report Layout – Dynamics NAV
      Microsoft remove preview
      Create blank Word report layout on a report from Development Environment and modify the layout to include dataset fields and define a general format.
      View this on Microsoft >
      Lastly a good tutorial and learning nuts to bolts it the Packet Publishing ebook Microsoft Dynamics NAV 2015 Professional Report and start reading chapter eight
      Microsoft Dynamics NAV 2015 Professional Reporting | PACKT Books
      Packtpub remove preview
      Discover tips and trick for Dynamics NAV report building
      View this on Packtpub >
      How this gets you started
      Ronald McVicar
      IT Software Manager
      National Steak Processors, Inc.
      Owasso OK
    • Franz Kalchmair
      August 23, 2018 at 5:46 AM
      first start with standard reports 1304 – 1307. These are word reports.
      To create a word report:
      * Create a new report
      * add dataitem and columns (fields)
      * set report property “DefaultLayout” to “Word”
      * goto menu Extras/Word-Layout -> New, accept message with OK
      * save the new report
      * Now go again toĀ Extras/Word-Layout -> select EXPORT to export the word template, set a filename, save the word doc.Ā
      * Now open the word doc
      * In Word show the menu “Developing Tools”, select it, there click on “Xml MappingArea”
      * In the xml mapping select the last xml component “urn:microsoft-dynamics-nav …”
      * Under NavWordReportXmlPart you find the dataitem (record) structure.
      * add needed fields by right click on a field, “add control element” ->Ā  “only text”
      * save the word doc
      * re-import the word doc withĀ Extras/Word-Layout -> IMPORT in nav. dev.
      Franz Kalchmair
      Microsoft MVP
      Senior Consultant
      Austria, Europe
    • Ritu Sood
      August 23, 2018 at 8:09 AM
      Hi Laurie,
      To Customize a report in theĀ word, theĀ following steps need to be followed
      • Take any report e.g. 206 -Sales – Invoice
      • Open report in design mode
      • Click on Tools Ć  Word Layout Ć  New
      • Save & compile the report
      • Click on tools Ć  Word Layout Ć  Export
      • Save the word document in the desired path
      • Word document will be blank
      • Click on Developer tab Ć  XML Mapping Pane
      • On Right Hand side a XML Mapping pane will be opened
      • Select the desired report (urn:Microsoft-dynamics-nav/reports/Sales_Invoice/206/)
      • Design whatever layout you want (Suggest to start with simple layout)
      • Save the word file
      • Open report design of report 206
      • Click on tools Ć  word Layout Ć  Import
      • Select the file
      • Run the report
      • Choose the option Ć  Print Ć  Microsoft Word
      • Save or open the word report
      • Report will display the data in the following format
      Using this method any simple to complex report can be designed.
      Ritu Sood
      All E Technologies Inc.
    Unknown Member replied 7 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Customize a report’ is closed to new replies.
