Correcting Accented letters when bulk importing orders through written routine
  • Correcting Accented letters when bulk importing orders through written routine
    Posted by DSC Communities on April 7, 2017 at 7:44 am
    • Christine Cook
      April 7, 2017 at 7:44 AM
      Hi all
      This is my first post and I am a user not a programmer.  We have a xmlport that has been written to import orders to NAV16.  A lot of data we receive is accented, any ideas how the import can be changed to correct those accents?
      thanks
      Christine
      Christine Cook
      Procurement International Ltd
      Wokingham
    • Ian Ray
      April 7, 2017 at 10:01 AM
      You may want TextEncoding property.
      XMLports default to MS-DOS encoding.
      If you have access, open development environment, go to the relevant XMLport, select “File” from the top menu and “Export,” give the xmlport a name and save (this is to import again in case anything goes wrong).
      While still selecting the relevant xmlport, right-click and select “design,” choose a new line at the bottom with blank Node Name, right-click and select “properties,” change TextEncoding to something other than MS-DOS (UTF8, UTF16, or Windows).
      Close out of the design window, leave “compiled” checked and select “OK” to save.
      Finally, export a copy of the modifed xmlport to send your partner for their records.
      This page explains text encoding:
      https://msdn.microsoft.com/en-us/library/dn271702(v=nav.90).aspx
      I should note that this will preserve the characters rather than change them. If you import as MS-DOS, characters outside of the language set will import garbled. As far as I know, to change the characters to a specific set, you will have to change the xmlport code. There are some solutions in this thread involving deleting unwanted characters through code:
      https://dynamicsuser.net/nav/f/developers/50363/delete-all-the-special-characters-from-a-string
      Ian Ray
      Cypress Grove
      Arcata CA
    DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Correcting Accented letters when bulk importing orders through written routine’ is closed to new replies.
