Connecting w/ DBA, Admins
  • Connecting w/ DBA, Admins
    Posted by DSC Communities on January 5, 2017 at 8:13 pm
    • Sherman Daley
      January 5, 2017 at 8:13 PM
      Hi there:
      I recently join the NAV user group, I am a DBA and somewhat new to the NAV environment and looking for some good people to connect with. Certainly, if you are a DBA or a SysAdmin and you like to share the knowledge you have gained I would love to connect with you.
      Most of my previous environment I was able to manage some of what is currently managed by NAV i.e security, index etc. and now I find I need to learn NAV and its structure to get the sense I am addressing issues correctly.  Hence my motivation to make some connects to try to reduce my learning curve. If you have any suggestions or words of wisdom they are welcome.
      Either way, I would love to make some new NAV contacts. Thanks šŸ™‚
      Sherman Daley
      DBA / Developer .Net
      Event Network Inc.
      San Diego CA
    • Franz Kalchmair
      January 6, 2017 at 4:18 AM
      hi sherman,
      welcome!
      to learn more about dynamics nav you could start with following tutorials
      https://m.youtube.com/channel/UCXSvIwtWuxwVwH3bP_uJZnQ (very good)
      https://m.youtube.com/playlist?list=PLoS7gV-LINmnV0DWUgFo9ZTIzddqHLXli
      https://m.youtube.com/playlist?list=PLfmcUW0fYzCYv7nvzsPPT105WQ1Fg2o2R
      if you like to read about dynamics nav follow https://msdn.microsoft.com/en-us/library/hh173988(v=nav.90).aspx
      regards
      franz
      Franz Kalchmair
      Dynamics NAV Engineer and Consultant
      Microsoft MVP
      Vienna
    • Sherman Daley
      January 17, 2017 at 8:14 PM
      Franz,
      Thank you for the links it is much appreciated. Very helpful.
      Sherman Daley
      Event Network Inc.
      San Diego CA
    • Sherman Daley
      January 18, 2017 at 1:01 PM
      Hey Franz,
      Your video links turned out to be perfect for what I was looking for right now.
      We are moving to 2016 and needed some video the would help walk me through the front end and they nailed it.
      Sherman Daley
      Event Network Inc.
      San Diego CA
    • Doug Huras
      January 6, 2017 at 8:43 AM
      You mention security.  It can be a bear to deal with.  We have had some success with a product called NAV Easy Security from MergeTool.  You may be interested in it.
      http://mergetool.com/default2.html?gclid=Cj0KEQiAnb3DBRCX2ZnSnMyO9dIBEiQAOcXYHzZyurSA0KjbP2R4kPfUnvkYEoCMBlNYaDdMOYD1OvYaAi9E8P8HAQ
      Doug Huras
      Senior Software Developer
      Home Hardware Stores Limited
      St Jacobs ON
    • Sherman Daley
      January 17, 2017 at 8:16 PM
      Thanks Doug,
      I can definitely see where this will be useful. Much appreciated.
      Sherman Daley
      Event Network Inc.
      San Diego CA
    • Ian Ray
      January 6, 2017 at 10:12 AM
      Welcome!
      I would also recommend Easy Security. From a database perspective, Easy Security is especially useful to an administrator as it allows importing data from the SQL profiler to create a unique permission set. Practically, this means tasks can be performed in a test environment, required access recorded, and all relevant permissions to perform those tasks merged into a production environment. Additionally, Easy Security can limit page access which is something that would take countless hours to do otherwise considering the quantity of pages.
      The alternative is a tedious exercise of manually setting the particular “yes/indirect” “read/insert/modify/delete” permissions on each table for each task. This involves the “users” and “permission sets” pages. A permission set can be created by first running through a desired task as a test user in a test environment, noting each table access message, setting the correct permission in a new permission set, copy/paste the rows of that test permission set into a production environment permission set, and finally assigning the user(s) the permission set in a production environment. In my opinion, the worst part of this sort of manual process is assigning the permission set to all the relevant users which is another thing Easy Security takes care of by allowing grouping of users.
      The help page for permission sets in NAV:
      https://msdn.microsoft.com/en-us/library/dd568740(v=nav.90).aspx
      There are also many stock permission sets in NAV. These can be quite useful, but I would recommend examining them prior to assigning them to users as some of these stock permission sets grant permissions to things you likely don’t want to.
      Ian Ray
      Cypress Grove
      Arcata CA
    • Franz Kalchmair
      January 8, 2017 at 3:28 PM
      for security issues follow https://msdn.microsoft.com/en-us/library/dd355294(v=nav.90).aspx
      regards
      Franz Kalchmair
      Microsoft MVP
      Vienna
    DSC Communities replied 9 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Connecting w/ DBA, Admins’ is closed to new replies.
