Chemical Manufacturing
Posted by Kim Dallefeld, MVP on September 24, 2019 at 5:36 pm-
Does anyone know of or utilize a chemical manufacturing add-on to NAV that resides in NAV? I’ve had several people recommend Vicinity but it sits outside of NAV and client wants a solution that is NAV objects only?
Thanks for your ideas?
Kim Dallefeld
Kim@Dallefeld.com
Dallefeld Consulting, LLC
Ft. Worth, TX
2019 NAVUG Board of Advisors
Past NAVUG Board Chairman
NAVUG Programming Committee
Darren Atkins
MemberSeptember 25, 2019 at 2:39 AM
Hi, Kim.You might want to check Yaveon.
Darren
Darren Atkins
Strategic Account Manager
Advanced Business Systems, LLC
Metairie LA
Justin Falconer
MemberSeptember 25, 2019 at 9:33 AM
We use Columbus IT ISV,Ā It is now called Columbus Food, when we started with it was marketed as Food and Chemical
There solution fits our business and maybe worth looking into.——————————
Justin Falconer
Tender Corporation
Littleton NH
Joshua Hatton
MemberSeptember 25, 2019 at 10:28 AM
Hi Kim,ĀThanks, Justin. Columbus does, in fact, have a process manufacturing add on that seamlessly integrates with NAV/BC. So, you cant really tell where one ends and the other begins. I would say that the majority of our NAV and BC clients run the ColumbusFood application suite, which works great for all of process manufacturers. Feel free to ping me if you want more info.
Joshua Hatton
Client Success Manager
Columbus Global
josh@columbusglobal.com
7208977565
Geovanny Fuentes
MemberSeptember 26, 2019 at 6:09 PM
I used one of these in the past. Can’t remember which one.
ttps://www.archerpoint.com/sites/default/files/docs/ms-dynamics-nav-chemical-manufacturing-factsheet.pdf
Microsoft Dynamics NAV for Chemical Manufacturing | CBIZ
CBIZ remove preview Microsoft Dynamics NAV for Chemical Manufacturing | CBIZ Estimation & insight Find out insightful information about customer, product and job/ production performance. Quote accurately, competitively and faster with latest costs, resources and prices available at the click of a button. Speed up the estimation process using information readily available in one system, allowing production to start quicker and customer promises to be met with ease and less overtime. View this on CBIZ > ERP For Chemical & Fertilizer Industry | Dynamics Square
Dynamicssquare remove preview ERP For Chemical & Fertilizer Industry | Dynamics Square The Chemicals and Fertilizers Industry faces a lot of unique challenges that have to be addressed if an organization into this business is serious about doing well. Costs incurred during production are on the higher side. Margins are low. Companies manufacturing chemicals and fertilizers ought to have tight control and greater visibility as far as operations are concerned. View this on Dynamicssquare > Good luck in locating the add-on.
Geovanny Fuentes
San Diego CA
Kim Dallefeld, MVP replied 5 years, 11 months ago 1 Member · 0 Replies -
The discussion ‘Chemical Manufacturing’ is closed to new replies.
