Canadian Dates: Best buy and Production Date
  • Canadian Dates: Best buy and Production Date
    Posted by Ronald L McVicar Jr on September 10, 2018 at 3:58 pm
    • Ronald McVicar
      September 10, 2018 at 3:58 PM
      This is a reach out to the RDLC experts regarding Datetime data elements.
      we have a dataset in NAV that gives us a datetime.Ā  For all our US customers we useĀ  CDATE expression and format as we want.Ā  However for Canadian we are told we need to use letters for month instead of numbers: Ā JA, FE, MR, AL, MA, JN, JL, AU, SE, OC, NO, DE
      so instead of 190613 for June 13, 2018 we are to format 19JN13
      Any recommendations and examples?Ā
      The following is what we thought we’d use but instead of numbers for month we have to use letters.
      =Format(CDATE(First(Fields!Label_Parameters__Expiry_Date_.Value, “DataSet_Result”)), “yyMMdd”)
      NSP (Quality Meats)
      nspproteins.com
    • Suresh Kulla
      September 11, 2018 at 2:23 AM
      Ronald,
      You can use MMM to get the month name in three characters. for ex: JAN, FEB… but to get in to your format i recommend you add a custom function and pass the MMM value and return the 2 character.
      Something like below and your final expression could like
      =Format(CDATE(First(Fields!Label_Parameters__Expiry_Date_.Value, “DataSet_Result”)), “yy”) +Ā  GetMonth(Format(CDATE(First(Fields!Label_Parameters__Expiry_Date_.Value, “DataSet_Result”)), “MMM”)) +
      Format(CDATE(First(Fields!Label_Parameters__Expiry_Date_.Value, “DataSet_Result”)), “dd”)
      Public Shared Function GetMonth(ByVal MonthName As String) As StringĀ Ā Ā Ā
      Ā Ā Ā Ā Ā Ā Ā  Select Case MonthNameĀ Ā Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Case JANĀ Ā Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Return “JN”Ā  Ā Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Case FEBĀ Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Return “FB”Ā Ā Ā
      Ā  Ā  Ā  Ā  Ā  Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Case ElseĀ Ā Ā Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Return “”Ā Ā Ā
      Ā Ā Ā Ā Ā Ā Ā  End SelectĀ Ā Ā Ā
      Ā Ā Ā  End FunctionĀ Ā Ā Ā
      Suresh Kulla
      NAV Technical Architect
      Atlanta GA
    • Ronald McVicar
      September 19, 2018 at 11:49 AM
      Suresh
      what a great recommendation. I use this in SQL scripting but not in SSRS (Report Builder: Expression).Ā  I’ll work on it.Ā  This should work.Ā  I believe.
      NSP (Quality Meats)
      nspproteins.com
    Ronald L McVicar Jr replied 8 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Canadian Dates: Best buy and Production Date’ is closed to new replies.
