Amazon Direct Fulfillment Case Sensitive PO #
  • Amazon Direct Fulfillment Case Sensitive PO #
    Posted by Noreen Fujita-Sacco on November 21, 2022 at 2:28 pm
    • Noreen Fujita-Sacco
      November 21, 2022 at 2:28 PM
      We’re on NAV 2018 using Lanham EDI.
      Amazon DF requires a case sensitive Purchase Order #. I can bring in case sensitive Mixed and see it in the raw file but in the External Document No field on the Sales Order and any lists, the PO # is changed to Upper. I can try mapping an EDI In as case sensitive for outbound documents. However, we have PO # validation. I’ve manually tested entering a Sales Order with a different mixed case PO# and receive the duplicate PO alert. This would also cause an issue searching for a particular PO #.
      Does anyone know how that validation is affected for EDI? That is, will it validate against the incoming raw file’s Mixed value?
      Has anyone resolved the Mixed case PO # for search or manual entry?
      Thank you!
      Noreen Fujita-Sacco
      Applications Coordinator
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
      noreen.fujitasacco@gearaid.com
    • Margaret Mextorf
      November 22, 2022 at 12:01 PM
      Hi Noreen,
      Thank you for your question! As you said, using an EDI In on the inbound mapping for the PO # will preserve the case sensitive number and the same EDI In can be mapped on the outbound document. The External Document No. field is a code field which is why the value is stored as all upper case – with the duplicate PO check mapping tool in use, it would give you the duplicate error if the same letter/number combination is used as the PO # regardless of case. I have never seen Amazon do this, however, and it would be easy to check the PO #s against each other in the rare case that it happens. If you’d prefer to turn off the duplicate PO # check, remove the “Validation Type” field = “Purchase Order No.” on the External Document No. element mapping. I hope this helps!?????
      Margaret Mextorf
      EDI Support Specialist
      November 22, 2022 at 12:14 PM
      Thank you, Margaret.
      We wouldn’t want to turn off validation. It’s good to know you’ve never seen a duplicate, though.
      Noreen Fujita-Sacco
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
    • Ruthie Moshos
      November 22, 2022 at 1:40 PM
      Hi, Noreen-
      I agree with the EDI In as a second conditional, and you could also add a third conditional to map it to Nav-E.D.I Recieve Doc Hdr Info into one of the Text Fields. You can use this to map out of if you need to print case sensitive on a UCC label or another document.
      Ruthie Moshos
      EDI Specialist
      Western Computer
      santa clarita CA
      November 22, 2022 at 5:50 PM
      Thank you, Ruthie.
      Happy Thanksgiving!
      Noreen Fujita-Sacco
      Coghlan’s/Gear Aid
      Bellingham WA
      360-392-2703
    Noreen Fujita-Sacco replied 3 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Amazon Direct Fulfillment Case Sensitive PO #’ is closed to new replies.
