Generally, when planning for an item using the Planning or Requisition Worksheet, the system will use the default vendor on the item card when adding the purchase suggestion on the worksheet. The exception to this goes back to Amanda’s question on whether you’re using Stockkeeping Unit Cards by location. If so, you can specify the default vendor for the item for that specific location. As a result, on the planning worksheet, it there is demand for that item at the specific location, the system will first look to the SKU card for the vendor before going back to the item card for the vendor. This can really help purchasing as different locations may source items from different vendors.
