sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return same positive value
sridhama Kundur
sridhama KundurMay 27, 2022 02:52 AM
sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return …
1. sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return same positive valuesridhama Kundur
Posted May 27, 2022 02:52 AM
sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return same positive valueHere in the sales over annual quota , Negative amount must return as zero for Trauma and same positive amount is already correct showing up under Extremities.
I Tried IF Then Else logic (0+$4,22,47,253 = 0) didn’t worked , will return sum of these two numbers as zero.
As said ($2,81,07,54,662) as 0+$4,22,47,253 = $4,22,47,253 (Desired Output)
Need help on other way of work around to build using Dax measure.——————————
sridhama Kundur
——————————2. RE: sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return same positive value
Adam Artur Boltryk
Posted May 28, 2022 05:12 AM
Hi Sridhama,strange numbers you have š
What about SWITCH(TRUE(),[Variance to Quota]<0,0,[Variance to Quota])
Regards
Adam Artur Boltryk
Business Analyst
——————————3. RE: sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return same positive value
sridhama Kundur
Posted May 29, 2022 05:15 AM
Hi Adam,Thank You for your suggestion
when I use switch dax function, am seeing total as zero..
Total must be $4,22,47.253 rightNeed an dax measure to resolve this.
Thank You
sridhama Kundur
The discussion ‘sales over annual quota(Sales-Quota) Total value if Negative must return zero and if positive return same positive value’ is closed to new replies.
