Table 1 has a field that is either Invoice or Credit, and a field with a Document No.Ā I concatenated the 2 fields to create a new one called Doc No. Type EG: AmountĀ Ā TypeĀ Ā Ā Ā Ā Ā Ā Ā Ā Doc No.Ā Ā Doc No. Type $100Ā Ā Ā InvoiceĀ Ā Ā Ā Ā Ā Ā Ā Ā 101Ā Ā Ā Invoice-101 $200Ā Ā Ā InvoiceĀ Ā Ā Ā Ā Ā Ā Ā Ā 202Ā Ā Ā Invoice-202
When I create a 1:n join between Table 1 and Table 2 – and add a field from Table 1 to a “Table” visualization, all is fine.Ā When I added a field from Table 2 – all records cleared and no data was visible.
As I played around sometimes the payment was visible, sometimes nothing etc…
So I started a new tab and dragged in the fields from Table 2 and started adding Table 1 just to see what would happen.Ā That worked fine.Ā I can rearrange the fields to the exact order I wanted to.
Does anyone have any idea why this happened?Ā It is essentially an outer join as Table 2 has records in it that aren’t n Table 1.Ā I am a little confused by the join types in Power BI modelsĀ – I’m an old hand at SQL but I do find the limits of not being able to use compound keys very limiting and the cross filters etc…Ā Could that be what the issue is?Ā Is there a primer on this stuff for someone who knows SQL?
Maybe I should do this in the the power query as merging queries and expanding Table 2 … maybe do this with transformations not in the model relationships?Ā I just really don’t want to have to do magic to get the SUM of the invoice 202 as I would probably end up with a new query where it shows 2x where the 2 are merged into 1.
Thanks in advance!
-Rob
—————————— Robert Jolliffe President Sabre Limited Cambridge, Ontario Canada 5195857524 ——————————
William Skelley
March 26, 2021 at 3:24 PM
Hi Rob:
There are all sorts of table functions for you to use. Summarize, Summarize Columns, CROSSJOIN, Intersect, etc.Ā
If you have an example of some tables and the result you are seeking I can try to help. It’s great to have the data to work with.
Bill
—————————— William Skelley 01106 Longmeadow MA 8602807221 —————————— ——————————————-
