PowerApps Flows not showing up
  • PowerApps Flows not showing up
    Posted by DSC Communities on April 22, 2022 at 11:07 pm
    Fabian Heil
    Fabian HeilApr 22, 2022 09:35 AM
    I want to use a powerautomate flow in my PowerApp. I tried to open the “PowerAutomate” Pane in my PowerApp, …
    1. PowerApps Flows not showing up
    Fabian Heil
    Posted Apr 22, 2022 09:35 AM
    I want to use a powerautomate flow in my PowerApp. I tried to open the “PowerAutomate” Pane in my PowerApp, but there arent any flows showing up (although i have many instant flows with PowerApps Trigger in this environment). So i tried to create a new flow out of PowerApps. This opens a popup where i can edit the flow.
    But this new created flow is not showing up in the “my flows” sections where i can check the flow history.
    Where do i find my new PowerApp flow or how can i add an existing flow to my PowerApp? Was there a change?
    Some month ago, this was working fine.
    Fabian Heil
    2. RE: PowerApps Flows not showing up
    Gold Contributor
    Alaa Bitar
    Posted Apr 25, 2022 05:41 AM
    Hello Fabian,
    In order for the flow to appear it trigger must be either PowerApps or PowerApps V2 as shown in the print screen
    Best regards,
    Alaa
    Alaa Bitar
    Modern Workplace Architect
    Serial Sa
    3. RE: PowerApps Flows not showing up
    Fabian Heil
    Posted Apr 25, 2022 05:50 AM
    There are multiple flows with this trigger, but they are not showing up anyway
    Fabian Heil
    4. RE: PowerApps Flows not showing up
    Fabian Heil
    Posted Apr 25, 2022 05:53 AM
    Fabian Heil
    5. RE: PowerApps Flows not showing up
    Bronze Contributor
    Stefan SauerlƤnder
    Posted Apr 26, 2022 01:02 AM
    Hi Fabian,
    is your app part of a solution? If yes, I had the same issue of flows not showing up and solved that by adding the flow from within the solution
    Stefan
    Stefan SauerlƤnder
    Business Analyst
    Ratingen
    6. RE: PowerApps Flows not showing up
    Steve Hanzelman
    Posted Sep 21, 2022 11:52 AM
    Hello Stefan,
    I’m having the same issue as Fabian, but am unable to even see the Flows when I’m in my solution.
    The application and flows work perfectly fine, but when I go to the solution to add them I can’t see the flows at all.
    When I export the solution and manually export the flows, the application isn’t able to see them just as in Fabian’s case.
    Any ideas?
    Steve
    Steve Hanzelman
The discussion ‘PowerApps Flows not showing up’ is closed to new replies.
