?IĀ need to add one column to an existing table. But the values come from the column in a different table. Add column from table below
Add it to this table
I don’t care about order, I can sort it later. Just need to add this particular column to the table. I know, it’s only two records, but this is just a test for larger datasets
—————————— Michael Michniadowicz 2102078768 ——————————
Farhan Ahmed
August 30, 2019 at 1:00 AM
Do you have any joining condition between your tables? If yes, try use “MERGE Queries”Ā
If where is no joining keys between tables then create 1 column in Table with with Value = 1 ,and same column in Table 2 with Value =1 Then use merge and join both tables, it will create Cross Join between your tables.
—————————— Farhan Ahmed Senior Business Intelligence Consultant karachi 3452523688 —————————— ——————————————-
Peter Sladen
August 30, 2019 at 5:05 AM
Assuming the tables are appropriately related in your model then you can create a calculated column in your second table and say something like NewColumn = RELATED(GoalValue) The “appropriately related” bit is important. You might need to aggregate if second table is at higher grain, or you might get duplicate values if at lower grain.Ā I find this a quicker and easier way of doing this kind of thing if it’s all I need from the other table, and I don’t want to simplify the model for any other reasons, otherwise Farhan’s suggestion of merging etc is probably the way forward.
—————————— Peter Sladen Data Developer 7220502304 —————————— ——————————————-
