I’m trying to take identical tables from 3 separate database instances and merge them together. The challenge is that I want to be able to identify the database (company) each row came from once the data is merged in BI. I’ve tried assigning a company ID in a custom column in each table, but when I append I end up with the company ID I assigned in the primary table in all the appended rows as well. I tried doing a merge new, but even though I say I want all rows from both tables,Ā it still wants to match on something, and I don’t want to match. I just want to merge multiple identical tables into one table with a custom company id that identifies where each row came from so I can use it in a slicer so the user can see individual company numbers as well as over all corporate numbers.
—————————— Charlie Haight Cedar Springs Technologies ——————————
Lutz Bendlin
April 15, 2020 at 10:55 AM
You want to use append, not merge .Ā (NOTE: Technically it doesn’t matter, both result in Table.Combine() )
Append it what I tried to do before I tried the merge new. Table 1 I added a custom column called Co_Id assigned a value of BRS. Table 2 I did same and assigned a value of FNET. If I append table 2 to table 1, I end up with BRS in all the rows.
—————————— Charlie Haight Cedar Springs Technologies —————————— ——————————————-
Lutz Bendlin
April 15, 2020 at 12:40 PM
Make sure you use the same spelling for the column name. Power Query is case sensitive.
—————————— Lutz —————————— ——————————————-
Ben Howard
April 15, 2020 at 3:39 PM
This works fine for me, please see attached pbix file where I merge two tables as you describe.Ā As Lutz says, spelling/case might be the problem.
