Match a value from a table with one from another table
  • Match a value from a table with one from another table
    Posted by DSC Communities on July 4, 2022 at 6:41 pm
    Mihai Stanca
    Mihai StancaJul 04, 2022 11:53 AM
    Hello guys Please help me with a DAX solution for this case I have 2 tables without a relation, one …
    1. Match a value from a table with one from another table
    Mihai Stanca
    Posted Jul 04, 2022 11:53 AM
    Hello guys
    I have 2 tables without a relation, one called “Services table” and another “Detail table” where the code detail it is written.
    I want to add a column in “Services table” where if DATA_U is greater than DATA_N, than “Finished” , else bring the code detail from column DETAIL TABLE.
    In excel i put the formula =IF(C2>B2,” Finished”,VLOOKUP(E3,J2:K13,2))
    I know that i can merge queries based on the code column and bring the detail intro one table but i need a DAX formula for this.
    Thank you
    Mihai Stanca
    Acasa
    2. RE: Match a value from a table with one from another table
    Vilmar Santos
    Posted Jul 05, 2022 11:53 AM
    Tente
    Medida =
    IF (
    [DATA_U] > [DATA_N],
    “Finished”,
    LOOKUPVALUE ( Tabela2[Code Detail], Tabela2[Code], Tabela1[Code] )
    Vilmar Santos
    3. RE: Match a value from a table with one from another table
    Adam Artur Boltryk
    Posted Jul 05, 2022 02:31 PM
    Hi Mihai,
    “I have 2 tables without a relation”
    Why? Your Detail table is PURE DIM table. Make relation on it.
    Do it like a Pro should do šŸ™‚
    @Vilmar Gave you one of solution, so no need more.
    Adam Artur Boltryk
    Business Analyst
    replied 3 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Match a value from a table with one from another table’ is closed to new replies.
