last 13 Month in visual
  • last 13 Month in visual
    Posted by DSC Communities on June 16, 2022 at 6:44 pm
    Ganesh Kumar
    Ganesh KumarJun 16, 2022 12:14 PM
    Hi All, i need help in DAX or any method to show last 13 month rolling in graph, attached two picture …
    1. last 13 Month in visual
    Silver Contributor
    Ganesh Kumar
    Posted Jun 16, 2022 12:14 PM | view attached (2)
    Hi All,
    attached two picture here , one is showing Jan to Dec data this what current am getting in my visual ,
    another one is may’21 to may’22 data in graph, this what am expecting in my graph,
    is it possible to achieve second (may to may data) graph using only calendar date ? if yes please help me. and this should be dynamic if am doing refresh in next month ( July) then my graph show Jun’21 to Jun’22 data in graph
    Ganesh Kumar
    Analyst
    e7781e6d-b751-4621-88da-7d18f7a99691_file
    Ɨ
    1 / 2
    2. RE: last 13 Month in visual
    Adam Artur Boltryk
    Posted Jun 18, 2022 05:31 PM
    Hi Ganesh,
    OFC – all is possible.
    However, you need some preparation.
    1) I assume, you have your calendar in DIM table. If not, it’s mistake, you have to fix in first instance.
    2) You have to create separate column with year and month, best as a number and I have always format YYYYMM -> 202201 202202 etc.It’s number and working good, and most important – when you sort it it’s always sort correctly.
    3) Create column with RANK – eg. ‘Month Rank’ ->
    RANKX(‘Calendar’, ‘Calendar'[YearMth], ‘Calendar'[YearMth], asc, dense)
    4) Create column RELATIVE
    Var currentmonth = LOOKUPVALUE(‘Calendar'[Rank], ‘Calendar'[Dates], TODAY())
    Return
    ‘Calendar'[Rank] – currentmonth
    Now just set filters on your visual – relative is Lower than 0 and bigger than -13
    Regards
    Adam Artur Boltryk
    Business Analyst
    3. RE: last 13 Month in visual
    Top Contributor
    Nicolas MENDEZ
    Posted Jun 24, 2022 05:37 PM
    As said by Adam Artur, it is a real best practice to use a calendar table, would say mandatory to use one šŸ™‚
    When calendar is connected to your Data table, then you measure will be :
    13 month rolling =
    VAR _MaxDate = EOMONTH( TODAY(), -1) –Retrieve the last day of previous month
    VAR _DatesRange = DATESINPERIOD(‘Calendar'[Date], _MaxDate, – 13 , MONTH) — Dates range to be used in the visual
    RETURN
    IF(
    MAX(‘Calendar'[Date]) IN _DatesRange,
    [Count of Requisition status]
    I hope this is a good start for you
    Nicolas MENDEZ
    Data & BI consultant
    Becom Consulting
    4. RE: last 13 Month in visual
    Silver Contributor
    Ganesh Kumar
    Posted Jun 27, 2022 06:40 AM
    Hi @Adam Artur Boltryk
    thanks for suggestion and its worked, ​now i have 13 month rolling month in my graph,
    Ganesh Kumar
    Analyst
    replied 3 years, 4 months ago 1 Member · 0 Replies
The discussion ‘last 13 Month in visual’ is closed to new replies.
