I have a datacard being displayed from a drop down that uses a field within an entity I have that can either be ‘Yes’ or ‘No’.
On the same screen I have an icon. I would like the icon to be different depending on the ‘Yes’ or ‘No’ value of the datacardvalue.
I tried the following in the ‘Icon’ property of the Icon:Ā If(DataCardValue30.Selected.Value=”No”, Icon.Draw)
However, there’s an error on the equals sign that says ‘Incompatible type. We can’t evaluate your formula because the values being compared in the formula aren’t the same type.’
—————————— Michael Seto Cloud Wiz ——————————
Michael Seto
April 15, 2020 at 10:11 PM
Anyone? Is this a tough one?
—————————— Michael Seto Cloud Wiz —————————— ——————————————-
Warren Belz
April 16, 2020 at 12:03 AM
HI Michael, The issue I believe is in the piece.
DataCardValue30.Selected.Value="No"?
If this is a Boolean field in the data source and (I assume) you are using a toggle or checkbox, it should be
I would look at two icons.Ā When a change is made it sets aĀ variable to true or false.Ā If true, the visible of one is true,Ā if false the visible of the other is true
—————————— Mark Pearson National Operations Manager 61409321547 —————————— ——————————————-
Ujjwal Sharma
April 16, 2020 at 1:30 AM
It tried it on my end and it works.
Are you sure the datacard is a drop-down and not a Combo Box?
If it is a combo box then you have to useĀ If(First(DataCardValue30.Selected).Value="No", Icon.Draw)Ā .
—————————— Ujjwal Sharma Software Developer India Delhi —————————— ——————————————-
Peter Heffner
April 16, 2020 at 1:41 AM
Michael, I think there is still any issue filtering Sharepoint lists with a boolean field. It always returns false. This is why I use text fields writing true/false or Yes/No as a text value.
Working with Sharepoint and SQL servers I have seen true/True/1 and false/False/0 When using toggles or checkboxes or dropdowns I often add a label to display the actual value of my selection just to reduce troubleshooting time. I hope this helps.
—————————— Peter Heffner Intranet Solution Specialist III —————————— ——————————————-
Brent Mason
April 16, 2020 at 10:36 AM
Could this be the magic line for which you are looking?
I added this to the ICON property of the icon:Ā If(Dropdown1.SelectedText.Value = “yes”, Icon.Draw, Icon.Airplane )
This swaps between the Draw and Airplane icons based on the “yes” or “no” from the dropdown.
