Getting a option set field value from a collection
  • Getting a option set field value from a collection
    Posted by DSC Communities on April 16, 2020 at 8:01 pm
    • Jack Kao
      April 16, 2020 at 8:01 PM
      Hi Everyone,
      Currently I have a collection that is populated with a single record from a Common Data Service entity. On my page I have a couple of labels that display fields from that collection. For example in my entity I have a field called ‘Description’. Currently I can show this on the PowerApps page via the formula:Ā First(Collection_Name).Description. But when I try to apply the same formula to a field that came from an option set, I’m getting a data type is not supported for evaluation error. I was wondering if there was a way to display a field from a collection that originally came from an option set field in a CDS entity.
      Jack Kao
    • Luc Vandael
      April 17, 2020 at 5:03 AM
      Hi Jack,
      What helped me in using option set and lookup values from PowerApps is the realization that the “references” used are not fields but entities on their own.
      So First(Collection_Name).YourOptionSet.Value should be possible.
      An Example:Ā First(colInvoiceHeaders).Currency.’Currency Name’
      Luc Vandael
      Business Analyst
      Tomra
      Haasrode
    • Mark Pearson
      April 17, 2020 at 4:10 PM
      Are you using the same filter that you use for the collection? The Collection is a result so unless there is only one row in the source it would need a filter to get that result.Ā  So is the label. text something like:Ā  First(Filter(source,Col-?)).Description
      Mark Pearson
      National Operations Manager
      61409321547
The discussion ‘Getting a option set field value from a collection’ is closed to new replies.
