Changing the MonthName sort orfer
  • Changing the MonthName sort orfer
    Posted by DSC Communities on February 11, 2022 at 11:41 pm
    Changing the MonthName sort orferFollow
    GƩrard Ducouret
    GƩrard DucouretFeb 11, 2022 06:37 AM
    Hello, In a matrix, the MonthName column is sorted by alphabetical order.. Previously, to solve this …
    1. Changing the MonthName sort orfer
    Top Contributor
    GƩrard Ducouret
    Posted Feb 11, 2022 06:37 AM
    Previously, to solve this issue, in the Data view, I clicked the Sort by Column button in the Modeling ribbon.
    But now I don’t find anymore this button.
    How can I do that?
    Thanks and regards
    GƩrard Ducouret
    2. RE: Changing the MonthName sort orfer
    Top Contributor
    Mehdi HAMMADI
    Posted Feb 11, 2022 10:33 AM
    Hi @GƩrard Ducouret,
    The button is available in the “Column tools” on the “Report” view.
    The feature is also available under the “Advanced” section of the “Properties” pane in the “Model” view​
    In both cases you need to select a column i the “Fields” pane
    If any discussion or answer help, please mark it as “Recommend”
    Best regards
    Mehdi HAMMADI
    MCT | MCSA BI Reporting | MCSE Data Management and Analytics | Data Analyst Associate
    2019 Ruby Award Dynamic Communities
    3. RE: Changing the MonthName sort orfer
    Top Contributor
    GƩrard Ducouret
    Posted Feb 11, 2022 11:37 AM
    Thanks a lot Mehdi, that works !
    GƩrard Ducouret
The discussion ‘Changing the MonthName sort orfer’ is closed to new replies.
