auto-refresh of data from sources other than Azure or Analysis Services?
Posted by DSC Communities on April 7, 2017 at 9:36 am-
Hans Son
MemberApril 7, 2017 at 9:36 AM
Hi all,has anyone done auto-refresh of data from relational sources other than Azure or Analysis Services? i have my dw on redshift and mysql… not sure what my options are.—
Adrien Bailly
MemberApril 10, 2017 at 4:17 AM
HiĀ Han So,You can refresh a SSAS datasetĀ though Power BI Gateways and Power BI Services.
I advise you to look those two greatĀ tutorials from Power BI community blog.Microsoft remove preview
Configuring scheduled refresh | Microsoft Power BI If your dataset supports scheduled refresh, by using Refresh Now and Schedule Refresh, there are a few requirements and settings important for refresh to be successful. These are Gateway connection, Data Source Credentials, and Schedule Refresh. Let’s take a closer look at each. View this on Microsoft >
SQL Server Analysis Services live data in Power BI | Microsoft Power BIMicrosoft remove preview
SQL Server Analysis Services live data in Power BI | Microsoft Power BI In Power BI, there are two ways you can connect to a live SQL Server Analysis Services server. In Get data, you can connect to a SQL Server Analysis Services server, or you can connect to a Power BI Desktop file, or Excel workbook, that already connects to an Analysis Services server. View this on Microsoft >
Cheers,——————————
Adrien Bailly
BI & Analytics Bid Manager
Activus-SERVICES
TOULOUSE
0661762947
Alejandro DomĆnguez
MemberApril 10, 2017 at 12:34 PM
Hi,Ā
Well, i’ve several connections (only from SQL, but some differents), if you’re querying the source litteraly with a query you’ve to set up auto refresh with the data set. Below an example:
Also i have a lot of connections SSAS type, and with this one is easier because you don’t have to schedule an automatic refresh, it’s an automated data source. But in your back end you’ve to set up any jobĀ to process your information.
For example in SQL Agent. Once you’ve this, you will have your data online.
I Hope i’ve helped.——————————
Alejandro DomĆnguez
Business intelligence Consultant
Zapopan
+52 1 3313727132
Hans Son
MemberMay 11, 2017 at 9:34 AM
cool – it seems it only direct connects to Miicrosoft DB’s of which i have none. Ā I only have MYSQL, Amazon Redshift and Google BigQuery/ GA. Ā I see we can manually refresh MYSQL using a schedule – how about Redshift?——————————
Han So
20815
Chevy Chase MD
3012319473
Hariharan Rajendran
MemberMay 12, 2017 at 4:22 AM
Ā Amazon Redshift is supporting direct query which means you can use the gateway to connect with your data source and can schedule the refresh.Ā Ā Use DirectQuery in Power BI Desktop | Microsoft Power BI
Use DirectQuery in Power BI Desktop | Microsoft Power BI With , when you connect to your data source, it is always possible to import a copy of the data into the Power BI Desktop. For some data sources, an alternative approach is available: connect directly to the data source using DirectQuery.View this on Microsoft > ——————————
Hariharan Rajendran
9543145504
Brandon Judge
MemberApril 11, 2017 at 11:55 AM
Hi Hans-Also note that you’ll need to install a Gateway if using any on-prem DBs.Ā Ā The gateway comes in two formsĀ (for either personal andĀ enterpriseĀ application), andĀ passes a user’sĀ server permissions to the PowerĀ BI service.
Power BI Gateway | Microsoft Power BI
Microsoft remove preview Power BI Gateway | Microsoft Power BI With the on-premises gateways, you can keep your data fresh by connecting to your on-premises data sources without the need to move the data. Query large datasets and benefit from your existing investments. The gateways provide the flexibility you need to meet individual needs, and the needs of your organization. View this on Microsoft > R
Brandon Judge
Business Analyst
Bellevue WA
406-249-6513
DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies -
The discussion ‘auto-refresh of data from sources other than Azure or Analysis Services?’ is closed to new replies.
