Attachments Control in Scrollable Screen
  • Attachments Control in Scrollable Screen
    Posted by DSC Communities on March 30, 2022 at 11:10 pm
    Fabian Heil
    Fabian HeilMar 30, 2022 10:57 AM
    Hi, i have a form that consinsts of multiple galleries and input fields to have repeating tables in …
    1. Attachments Control in Scrollable Screen
    Fabian Heil
    Posted Mar 30, 2022 10:57 AM
    i have a form that consinsts of multiple galleries and input fields to have repeating tables in it. So, i used the screen template “Scrollable screen” to structure the different parts and to have a scrollbar. The data of the collections is patched to different Lists after saving. Now i need to add the possibility to add attachments to the form. As i dont use the form control, i dont find a way to add this. I tried to add an additional form controll just for the attachments field, but it seems that it is not possible to add it into the scrollable screen datacards. Is there any other way to add files and patch it to sharepoint without using the form control attachments?
    Fabian Heil
    2. RE: Attachments Control in Scrollable Screen
    Silver Contributor
    Koen Mathijs
    Posted Mar 31, 2022 03:01 AM
    Hi Fabian,
    the trick is to insert the attachment control in a form, copy/paste the control outside the form and then delete the form again. You can then use a Power Automate flow to upload your file to wherever you want.
    Matthew Devaney has made a very nice tutorial about this: https://www.matthewdevaney.com/power-apps-easiest-way-to-upload-files-to-a-sharepoint-document-library/#Insert-An-Attachments-Field
    I think this is what you want?
    Koen Mathijs
The discussion ‘Attachments Control in Scrollable Screen’ is closed to new replies.
