Arcgis tool, mapping problems
  • Arcgis tool, mapping problems
    Posted by DSC Communities on March 28, 2017 at 6:34 am
    • Philip Weston
      March 28, 2017 at 6:34 AM
      I need some advise on mapping data on the ArcGIS tool. I tend to get UK Postcodes map across the World, amongst a few other tasks that I find a challenge. Any advise would be most welcome>
      Philip Weston
      Project Manager
      Uponor
      Kettering
      01923927000
    • Niels Skytte
      March 29, 2017 at 2:57 AM
      Look at this thread Problem with map and postal code I’m guessing you’re seeing the same issue. So try to add United Kingdom before the postcodes.
      regards Niels
      Niels Skytte
      Architect
      Copenhagen K
      93979808
    • Dennis Jung
      March 29, 2017 at 5:02 AM
      Hey,
      i had the same issue and made a separate column for ArcGIS:
      Arcgiscolumn = “TableStreet” & “,” & TableZipCodeTown & “,” & TableCountry
      TableStreet and co. are columns in my dataset (need to change it to your columns)
      Dennis Jung
      Head of IT
      Kammerstein
      91789969990
    • Natalia García
      March 29, 2017 at 7:51 AM
      There is a quick workaround that may help you and it is to use the option for “all points are in one country” and then you select the country. That has worked for me in the past, but I have not used zip codes before so you would need to try it.
      Natalia García
    • David Wynn
      March 29, 2017 at 7:53 AM
      Philip,
      What is your base dataset?
      Are you doing any kind of zip code validation before importing into PowerBI?
      Do you want to see zip codes from the US only?
      I had an issue where the data wouldn’t map correctly using a county or state name. I used the zip code instead after using an inner join on a zip code look up table, it fixed my problem.
      ______________________________________________
      David Wynn
      Business Intelligence & Application Developer
      South Carolina Aquarium
      100 Aquarium Wharf
      Charleston, SC  29401
      Direct Line: (843) 579-8559
      scaquarium.org
      Logo-Email
      ——Original Message——
      Philip Weston
      Project Manager
      Uponor
      Kettering
      01923927000
    • Andrea Martorana Tusa
      March 29, 2017 at 8:22 AM
      I want to add a tip to the previous (correct) answers.
      You can force Power BI to recognize your data as a geographic attribute. Select the data field and in the menu ribbon choose Modeling > Data Category and you can set the geographic category for your field.
      Combining zip codes & a custom code with my country name worked for me. Eg: [ZipCode] & ” ,Italia” => 40011, Italia.
      Senior BI Developer
      Banco Popolare
    DSC Communities replied 9 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Arcgis tool, mapping problems’ is closed to new replies.
