I’m creating a number of forms (one per machine) that are triggered when a team member scans a QR code. The QR codes are on the front of each machine. The form is then populated with the possible maintenance tasks for that machine and the tech choses which options apply. I have a flow populating the form details to an excel spreadsheet ‘Maintenance Master.
I need the form name to be populated on the excel spreadsheet as it represents the specific machine. I’ve not found a way to do this in PowerAutomate.
Has anyone been able to add a form name to an excel file through PowerAutomate?
Template being used: Track Microsoft Forms responses in an Excel Online (Business) spreadsheet File is not in OneDrive (for IP reasons cannot show actual file location) it is an excel file in a SharePoint location
—————————— Kelly Knecht Operations Support Redmond WA 4257038005 ——————————
Koen Mathijs
June 27, 2022 at 2:56 AM
Hi Kelly,
after you added the row into a table you can use the function “Modify a row in a table” and add the name of the form. I’m not sure if the name of the form is a dynamic value which you can retrieve from the form but it seems to me that you have a specific form for every machine so maybe you can hard code the name into the excel file?
Program Manager | Advanced Prototyping Center | P:+1 (425) 703-8005
This email message may contain confidential and privileged information. Any unauthorized use is prohibited.
If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
Kelly Knecht
July 19, 2022 at 4:55 PM
Hi Koen,
Thank you for the assist. Through trying your process I found a simple solution.
I added a column in the excel spreadsheet titled “Machine”. In each flow I manually entered the name of the machine in that field. i used Keyboard as a beta test.
—————————— Kelly Knecht Operations Support Redmond WA 4257038005 —————————— ——————————————-
Koen Mathijs
July 20, 2022 at 3:04 PM
Glad to hear you got it solved. This seems indeed the easiest way. Thanks for the update!
