U4GM Diablo IV Season 12 Necro Minion Leveling Guide
I keep coming back to Necromancer in Diablo IV Season 12 for one simple reason: minions let you play smart without playing sweaty. You’re not racing to land the perfect crit window every pull. You’re setting the board, then letting your crew do the dirty work. The best part is how well the build responds when your gear improves; when you upgrade your Diablo 4 Items, you feel it immediately because your army starts hitting harder and living longer right alongside you.
Why the army finally feels like an army
Season 12’s scaling makes summons feel less like disposable pets and more like an extension of your character sheet. Your attack speed matters. Your crit chance matters. Even your defenses and resistances help keep your minions from folding the second a boss looks at them. You’ll notice it fast: one strong ring or weapon roll can turn an “okay” pack clear into a clean wipe. That’s the hook for a lot of playersāevery upgrade is a squad upgrade, not just a personal DPS bump.
Levelling without the usual panic
Early on, the game plan is simple and it works. First, keep Raise Skeleton running and don’t let your numbers drop during messy fights. Second, lean on Decrepify to take the edge off incoming damage and slow the room down. Third, keep Blood Mist ready for when you get boxed in or a nasty affix combo shows up. And don’t ignore Corpse Tendrils while levellingāit’s the move that makes the whole screen behave. Pull enemies into a tight pile, let your mages go to work, then step to the side and repeat.
Endgame rhythm and the Naz Mages setup
Once you’re pushing tougher content, the build starts to feel like a routine you can settle into. You group mobs with Tendrils, reposition, then watch the Naz Mages do their thingāsnapping to targets, dodging danger, and chaining attacks through dense packs. It’s not flashy in the “one button deletes boss” way, but it’s reliable. That reliability matters in high-tier Pits and long dungeon runs, where mistakes add up and consistency wins.
Passives, survivability, and smart shortcuts
If your minions are dying, your damage is dying, so the passives aren’t optional. Hellbent Commander and Golem Mastery are where the pressure comes from, and Death’s Defense is what stops bosses from deleting your army in one bad moment. From there it’s about control and tempoācurse first, pull second, then let your summons chew through the stack. If you’re trying to speed up gearing or patch a weak slot without derailing your grind, a lot of players also use U4GM to buy currency or items and keep the build moving while they farm the rest naturally.
