U4GM Arknights Endfield Early Factory Loop Tips For Fast Gear
  • U4GM Arknights Endfield Early Factory Loop Tips For Fast Gear
    Posted by Hartmann846 Hartmann846 on March 13, 2026 at 2:54 am
    Arknights: Endfield hooks you in a weird way: you’ll show up for the RPG combat, then lose an hour rerouting power because one smelter keeps stalling. If you’re the type who likes starting fresh or just wants to compare progress with friends, browsing Arknights endfield accounts can also give you a clearer picture of what an established base looks like. The big difference here is that the “base” isn’t a side menu; it’s basically a living factory you’re expected to understand, even if you do it slowly.
    Getting past the first wall
    The Automated Industrial Complex (AIC) looks like a mess at first. Belts, poles, miners, storage boxes—stuff everywhere, and none of it feels optional. Don’t try to perfect it on day one. What actually helps early is chasing Data Loggers out in the world. They unlock AIC Index nodes, which then unlock Templates, and Templates are the real gate for expansion. Push Mining up to Level 3 as soon as you reasonably can. The Electric Mining Rig Mk II is the moment the game starts feeling less like manual labour and more like an actual system, since you can send minerals home without babysitting the route.
    Blueprints save your sanity
    Some players love laying out neat grids. Others just want their lines to stop clogging so they can go fight things. That’s where the Blueprint System earns its keep. You can save your own layouts, sure, but the underrated move is grabbing a shared design, dropping it, and tweaking it later when you’ve got time. It’s not “cheating,” it’s just using the tools. And because your factory grows in chunks, blueprints make it easier to rebuild cleanly when you unlock better machines and realise your first setup was a spaghetti disaster.
    The Loop and why it matters
    Endfield’s resource game isn’t about grabbing a plant once and moving on. You’ll run into “The Loop” fast, like with Buckflowers. You feed flowers into a Seed-Picking Unit to make seeds, belt those seeds into a Planting Unit, then route the output back so the chain sustains itself. When it works, it feels great—steady materials while you’re exploring, doing quests, or just logging off. Thermal Banks also change the vibe, because you’re not punished for stepping away; you’re rewarded for building something that keeps humming.
    Operators, promotions, and keeping pace
    Combat still matters, and the Operators are what make the grind worth it. At launch you’ve got six classes, and they don’t just hit differently—they solve different problems. Vanguards can smooth out skill point flow, Guards can delete a threat before it snowballs, and the rest fill in the gaps depending on your build. Stats are split into primary and secondary attributes, so upgrades aren’t always as simple as “more damage.” Promotions come in four stages, eventually letting you reach Level 90, and the material demand ties straight back into your factory output. If you’re short on key components and you don’t feel like waiting, a lot of players look at marketplaces like U4GM for game currency or items so they can keep their squad development moving without stalling their whole week.
    Hartmann846 Hartmann846 replied 1 week, 4 days ago 1 Member · 0 Replies
