Voided SOP invoices
  • Voided SOP invoices
    Posted by DSC Communities on January 9, 2017 at 12:34 pm
    • Christine Boisvert
      January 9, 2017 at 12:34 PM
      Hi there,
      When I go to Transactions – Sales – Print Sales Documents and I enter a range of Historical invoices to print, it’s printed voided invoices. Is there a way to exclude these invoices?
      Christine Boisvert
      Floform Countertops
      Winnipeg MB
    • Blair Christensen
      January 10, 2017 at 10:29 AM
      It doesn’t appear that the option you desire exists in the print output screen.  One thing you might check is to see if the sales order and its corresponding receivable (invoice) are both actually voided.  I use the following every month to verify that my documents are consistent and notify my Accounting department when something pops up:
      select rm.CUSTNMBR as Customer_ID
      , CAST(rm.DOCDATE as DATE) Doc_Date
      , RTRIM(rm.DOCNUMBR) as Doc_Number
      , case s.SOPTYPE
      when 3 then ‘Invoice’
      else ‘Return’
      end as Doc_Type
      , case rm.VOIDSTTS
      when 0 then ‘No’
      when NULL then ‘Not Invoiced’
      else ‘Yes’
      end as Voided_in_RM
      , case s.VOIDSTTS
      when 0 then ‘No’
      else ‘Yes’
      end Voided_in_SOP
      from (
      select CUSTNMBR
      , DOCDATE
      , DOCNUMBR
      , case RMDTYPAL when 1 then 3 else 4 end as SOPTYPE
      , VOIDSTTS
      from RM20101
      where RMDTYPAL in (1,8)
      union
      select CUSTNMBR
      , DOCDATE
      , DOCNUMBR
      , VOIDSTTS
      from RM30101 where RMDTYPAL in (1,8)
      ) rm
      inner join SOP30200 s on rm.SOPTYPE = s.SOPTYPE
      and rm.DOCNUMBR = s.SOPNUMBE
      where rm.VOIDSTTS <> s.VOIDSTTS
      order by case rm.VOIDSTTS
      when 0 then ‘No’
      else ‘Yes’
      end, rm.DOCNUMBR
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Lauri Romaniuk
      January 10, 2017 at 6:52 PM
      Hi Christine! I often instruct clients to use the Sales Transaction Navigation list to print and email historical invoices. Therefore I was leaning towards that as an option, adding a filter to exclude voids. This does not look like it is possible though.So as a second idea – do you have SmartList Builder? If so perhaps you could use it to create your own Nav. list with the restriction to exclude the voids as desired. Let me know ifhow you resolve this otherwise!
      Lauri
      Lauri Romaniuk
      Senior Solutions Specialist
      Encore Business Solutions
      Winnipeg MB
    • Rebecca Redman
      January 11, 2017 at 9:41 AM
      I’m curious about your reasons for using the Print Sales Documents option. Are you printing a list of invoices for a specific customer? Have you considered using Collections Main to print a group of invoices for a specific customer? It allows you to print any or all unpaid, posted transactions from the customer’s account. Since it’s only printing documents with a balance, voided documents would be excluded.  Is there a reason you are printing historical invoices instead of printing the unposted (‘Documents’) invoices. as these would automatically exclude voided transactions?
      Rebecca Redman
      PANDORA Jewelry
      Columbia MD
      January 11, 2017 at 4:14 PM
      They were using that window simply because that’s what they were used to. They like printing a specific range of invoices. I showed her how to print her invoices in her batch prior to posting. That process excludes voided invoices. It appears that the other way of doing it is a bug in GP 2015. When you print a range of historical invoices through the “Print Sales Documents” window it should be excluding voided invoices. Otherwise, there is no way for the use to know that the invoice that printed is voided.
      Christine Boisvert
      Floform Countertops
      Winnipeg MB
The discussion ‘Voided SOP invoices’ is closed to new replies.
