SSRS Subscription Error
  • David Morinello
    April 17, 2023 at 9:12 am
    First if you can, try running the report from the Azure server directly. This won’t fix anything but may give you more detailed errors.
  • Cory Severson
    January 3, 2024 at 9:52 pm
    Hi Drew,
    Did you get this figured out? I would recommend you look at the logs in SSRS. That will usually give some detail on the issue.
    C:\Program Files\Microsoft SQL Server Reporting Services\SSRS\LogFiles
    Let us know what that shows you.
    Cory Severson
    Velosio
  • Beat Bucher
    January 11, 2024 at 2:06 pm
    Hi @drewrosen ,
    Not sure if you got that ever sorted out or resolved.. but it was my recalling that Azure does not allow for e-mailing out of SQL or SSRS.. that’s an imposed limitation by Microsoft on the non-Enterprise subscriptions of Azure.. They want you to pay for something that was natively built-in to SQL server..
    Beat (aka GP Geek)
The discussion ‘SSRS Subscription Error’ is closed to new replies.
