SQL Query
  • SQL Query
    Posted by drosen@csfay.com on April 21, 2017 at 3:47 pm
    • Drew Rosen
      April 21, 2017 at 3:47 PM
      I have the following query that uses a multivalued parameter.Ā  The user would key in many order numbers which would then access the following query I am getting the following error message
      Msg 512, Level 16, State 1, Line 20
      Subquery returned more than 1 value. This is not permitted when the subquery follows =, !=, <, <= , >, >= or when the subquery is used as an expression.
      I do not know if there is another method of setting a variableĀ
      Here is the sql query
      declare
      @totalrate decimal(9,5) = 4.5,
      @driverexcess decimal(9,5) = .25,
      @multipledrivers varchar(1),
      @orderno varchar(max),
      @men int,
      @lead int,
      @driver int,
      @OrdPriKey int
      –AS
      set @multipledrivers=‘N’
      set @orderno=N’n04-28-15,bkas0087012,u1772-1025-7′
      –declare
      SET @OrdPriKey = (SELECT TOP 1 PriKey
      FROM moverssuite2.dbo.Orders orders WHERE OrderNo = (Select * From dbo.ParseMultiValuedParameter( @orderno,‘,’ ) ) AND Archived = 0)
      SET @men=(SELECT COUNT(DISTINCT CrewID)
      FROM moverssuite2.dbo.LocServ ls JOIN
      moverssuite2.dbo.LSCrew lsc ON ls.PriKey = lsc.LSPriKey WHERE OrdPriKey = @OrdPriKey )
      SET @lead=(SELECT COUNT(DISTINCT CrewID)
      moverssuite2.dbo.LSCrew lsc ON ls.PriKey = lsc.LSPriKey WHERE OrdPriKey = @OrdPriKey and
      lsc.LeadMan=1 )
      set @driver=(SELECT COUNT(DISTINCT CrewID)
      LaborTypeFID in (7,8,9))
      SELECT @men
      Select @lead
      Select @driver
      select b.OrderNo
      ,case
      when c.LeadMan=1 and @multipledrivers=‘N’ then (((@totalrate–@driverexcess)/@men)+@driverexcess)
      when c.LeadMan=0 and @multipledrivers=‘N’ then (((@totalrate–@driverexcess)/@men))
      when c.leadMan=1 and @multipledrivers=‘Y’ and c.LaborTypeFID in (7,8,9) then (((@totalrate-(@driver*@driverexcess))/@men)+@driverexcess)
      when c.leadman=0 and @multipledrivers=‘Y’ and c.LaborTypeFID in (7,8,9) then (((@totalrate-(@driver*@driverexcess))/@men)+@driverexcess)
      when c.leadman=1 and @multipledrivers=‘Y’ and c.LaborTypeFID not in (7,8,9) then (((@totalrate-(@driver*@driverexcess))/@men))
      when c.leadman=0 and @multipledrivers=‘Y’ and c.LaborTypeFID not in (7,8,9) then (((@totalrate-(@driver*@driverexcess))/@men))
      else 0
      end as rate
      ,* from
      MoversSuite2.dbo.LocServ a inner join
      MoversSuite2.dbo.Orders b on
      a.OrdPriKey=b.PriKey inner join
      MoversSuite2.dbo.LSCrew c on
      a.PriKey=c.LSPriKey inner join
      MoversSuite2.dbo.Sysuser d on
      c.CrewID=d.SysUserID inner join
      MoversSuite2.dbo.LaborType e on
      c.LaborTypeFID=e.PriKey
      where OrderNo=(Select * From dbo.ParseMultiValuedParameter( @orderno,‘,’ ) )
      Thanks for any help.Ā
      Drew G. Rosen
      Drew Rosen
      Carolina Services of Fayetteville, Inc
      Fayetteville NC
    • Matthew Arp
      April 21, 2017 at 3:59 PM
      FROM moverssuite2.dbo.Orders orders WHERE OrderNo = (Select * From dbo.ParseMultiValuedParameter( @orderno,‘,’ ) ) AND Archived= 0)
      This is incorrect, you can not have a OrderNo = (select *), SQL does not know what column you are trying to compare OrderNo to.
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • Matthew Arp
      April 21, 2017 at 4:03 PM
      More than Likely it should be
      OrderNo IN( SELECT Whatever FROM Parse….)
      Matthew Arp
      Hunton Group
      Houston TX
    • Blair Christensen
      April 24, 2017 at 12:32 PM
      I’d actually suggest looking to change your query to support a table variable.Ā  That will support the user being able to supply a list and you can join against the table to find the information desired.Ā  You can try using a WHERE [column value] IN clause, but that one is going to be dependent on the user putting commas in between each item they pass in.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    drosen@csfay.com replied 9 years, 7 months ago 1 Member · 0 Replies
The discussion ‘SQL Query’ is closed to new replies.
