I am trying to query vendors that has been one-time payment vendors.
Would anyone provide a sql query that will pull in vendors that has one doctype of either 1,2 or 3 AND a payment using doctype of either 4,5 or 6?
—————————— Lydia Ebinyo Derri OSU Physicians, Inc Columbus OH ——————————
Victoria Yudin
January 19, 2017 at 4:43 PM
Hi Lydia,
Try the following:
select VENDORID from PM00200 where VENDORID in (--vendors with only one debit select VENDORID from (select VENDORID from PM20000 where DOCTYPE in (1,2,3) group by VENDORID having count(*) = 1 union all select VENDORID from PM30200 where DOCTYPE in (1,2,3) group by VENDORID having count(*) = 1) a group by a.VENDORID having count(*) = 1 ) and VENDORID in (--vendors with only one credit select VENDORID from (select VENDORID from PM20000 where DOCTYPE in (4,5,6) group by VENDORID having count(*) = 1 union all select VENDORID from PM30200 where DOCTYPE in (4,5,6) group by VENDORID having count(*) = 1) a group by a.VENDORID having count(*) = 1 )
Victoria’s solution will certainly work. This should also work WITH TransRecs (Vendor, DocType) AS ( SELECT VENDORID, DOCTYPE FROM PO20000 UNION ALL SELECT VENDORID, DOCTYPE FROM PO30200 ) SELECT Vendor, COUNT(CASE WHEN DocType IN (1,2,3) THEN 1 ELSE 0 END) AS Type123, COUNT(CASE WHEN DocType IN (4,5,6) THEN 1 ELSE 0 END) AS Type456 FROM TransRecs GROUP BY Vendor HAVING COUNT(CASE WHEN DocType IN (1,2,3) THEN 1 ELSE 0 END) = 1 AND COUNT(CASE WHEN DocType IN (4,5,6) THEN 1 ELSE 0 END) = 1
—————————— Adam Jacobson President Red Three Consulting, Inc. Bronx NY —————————— ——————————————-
WITH TransRecs (Vendor, DocType) AS ( SELECT VENDORID, DOCTYPE FROM PM20000 UNION ALL SELECT VENDORID, DOCTYPE FROM PM30200 ) SELECT Vendor, COUNT(CASE WHEN DocType IN (1,2,3) THEN 1 ELSE 0 END) AS Type123, COUNT(CASE WHEN DocType IN (4,5,6) THEN 1 ELSE 0 END) AS Type456 FROM TransRecs GROUP BY Vendor HAVING COUNT(CASE WHEN DocType IN (1,2,3) THEN 1 ELSE 0 END) = 1 AND COUNT(CASE WHEN DocType IN (4,5,6) THEN 1 ELSE 0 END) = 1
I have not played with your query, but after a visual inspection I think there may be a problem with the four COUNTs in the query:
The COUNT function is going to count each row even if the DocType is not the (1,2,3) or (4,5,6) groups because they aren’t returning a NULL. Should you use SUM instead of COUNT? If you want to use the COUNT, should you return NULL in the ELSE clause instead of 0? I hope this helps!
—————————— John Arnold US Digital Vancouver WA —————————— ——————————————-
