SQL Query
SQL Query
Posted by drosen@csfay.com on May 8, 2017 at 11:28 am-
I have the following table:
PrikeyĀ Ā Ā Ā Ā Ā Ā Ā orderprikeyĀ Ā Ā statusdate
1Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 5Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 01/02/17
2Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 5Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 02/05/17
3Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 100Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 03/01/17
4Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 100Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 04/05/17
5Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 6Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 01/02/17I would like toĀ select the Ā with 1 record per orderprikey with the most current date ie
2Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 5Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 02/05/17
4Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 100Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 04/05/17
5Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 6Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā 01/02/17I tried the following
Select distinct prikey,orderprikey,MAX(statusdate) as statusdt
from Table
goup by prikey,orderprikey,statusdatethanks for your help
Drew Rosen
Carolina Services of Fayetteville, Inc
Fayetteville NC
Assuming that prikey is an Identity column (strictly increases) then the below will work.
SELECT t1.* FROM Table t1 INNER JOIN (SELECT MAX(prikey) prikey GROUP BY orderprikey) t2 ON t2.prikey=t1.prikey
Matthew Arp
Business Systems Developer
Hunton Group
Houston TX
I think your script will work if you remove the statusdate from the group by statement.
Val——————————
Valerie Sikora
InterDyn BMI
Roseville MN
Jeff Pfershy
MemberMay 9, 2017 at 11:29 AM
You can also use a CTE (Common Table Expression) to apply a row number to the orderprikey column and sort based on the statusdate in descending order. This creates a phantom row number for each statusdate record within the same orderprikey, and every time the orderprikey changes, the numbering starts again at 1.WITH My_CTE AS
Ā SELECT
Ā Ā Ā orderprikey
Ā Ā Ā Ā Ā ,statusdate
Ā Ā Ā Ā Ā ,ROW_NUMBER() OVER(PARTITION BY orderprikey ORDER BY statusdate DESC) AS ‘RowNumber’Ā Ā
Ā Ā Ā FROM table1
)SELECT
Ā Ā orderprikey
Ā ,statusdate
FROM My_CTE
WHERE RowNumber = 1
ORDER BY 1If I wanted to apply the same logic to AR invoices in GP and say, just get the most recent invoice for each GP customer, I could do something like this:
WITH Sales_CTE AS (
Ā SELECT
Ā Ā Ā CUSTNMBR as ‘CustomerID’
Ā Ā Ā Ā Ā ,DOCNUMBR as ‘InvoiceNumber’
Ā Ā Ā Ā Ā ,DOCDATE as ‘InvoiceDate’
Ā Ā Ā Ā Ā ,ORTRXAMT AS ‘InvoiceAmt’
Ā Ā Ā Ā Ā ,ROW_NUMBER() OVER(PARTITION BY CUSTNMBR ORDER BY DOCDATE DESC,ORTRXAMT DESC) AS ‘RowNumber’Ā Ā
—Ā Ā Ā Ā Ā ,ROW_NUMBER() OVER(PARTITION BY CUSTNMBR, DOCDATE ORDER BY DOCDATE DESC,ORTRXAMT DESC) AS ‘RowNumber’Ā Ā
Ā Ā Ā FROM RM20101
Ā Ā Ā Ā Ā WHERE RMDTYPAL = 1
Ā Ā Ā Ā Ā Ā Ā AND VOIDSTTS = 0
Ā Ā Ā Ā Ā Ā Ā AND ORTRXAMT > 0)SELECT
Ā Ā Ā CustomerID
Ā Ā ,InvoiceNumber
Ā Ā ,InvoiceDate
Ā Ā ,InvoiceAmt
FROM Sales_CTE
WHERE RowNumber = 1
ORDER BY 1Hope that helps
Jeff Pfershy
Solution Consultant
248-489-0707
The TM Group, Inc.
Farmington Hills MI
drosen@csfay.com replied 9 years, 6 months ago 1 Member · 0 Replies -
The discussion ‘SQL Query’ is closed to new replies.
