SQL Error after Posting Batch
  • SQL Error after Posting Batch
    Posted by DSC Communities on May 9, 2018 at 1:24 pm
    • Kinsley Buchanan
      May 9, 2018 at 1:24 PM
      Is anyone familiar with SQL Errors that occur sporatically? These errors cannot be traced on the SQL Log and are starting to occur rather frequently.
      Today, after posting a batch, I received the following error:
      ZsqfiLOHSEC9yaNfCmI3_error1.jpgWhen choosing More Info Tab:
      I entered another Batch and tried to print the Edit List and GP locked up.
      Can anyone advise on the cause of errors and steps to fix it?
      Kinsley Powers
      Buchanan Pump Service & Supply Company, Incorporated
      May 9, 2018 at 1:41 PM
      ?Hi ?
      My guess is that you may have a couple of instances of GP installed on that terminal server or computer.
      The first error is indicating that there is something not right about the ODBC setup you are accessing through GP.Ā
      Many people don’t know this, but one install of GP can access many different ODBC connections.Ā Ā  When you first log in to GP there is usually a drop-down box that says something like “Dynamics GP 2016”.Ā  This is the name of the ODBC connection.
      You may be accessing an incorrect database version as opposed to the GP version you are on, etc.
      The first thing we need to do is make sure you are using the correct ODBC connection.Ā  You may want to check with IT about that.
      If you don’t have an IT department, I am including aĀ link to an article to help resolve the first issue.Ā  Once the first issue is resolved it may help with the remainder of those error messages.
      https://support.microsoft.com/en-us/help/860468/error-message-when-you-start-microsoft-dynamics-gp-a-get-change-first
      Microsoft remove preview
      View this on Microsoft >
      Kindest Regards,
      Jo deRuiter
      “That GP Red Head”
      Member, GPUG GP Credentialing Exam Committee
      “……what isn’t she up to?”
      Milwaukee, WI
      770-906-4504 (Cell)
    • Beat Bucher
      May 11, 2018 at 9:20 AM
      Hi Kinsley,
      By any chances do you use any 3rd-party software that does close GP user’s sessions after a given time-out of inactivity ? Like Rockton Toolbox or Willoware ?
      Which build of GP are you using ?
      Beat Bucher
      Montreal QC/Canada
      GP2013R2 / MR2012 CU14
    • Beat Bucher
      May 14, 2018 at 2:48 PM
      Hi Kinsley,
      From your PM I understand that you don’t think there are any 3rd-party product that would time-out a user session ? Do you use FastPath for the GP login by any chances ? many company do in order to avoid the additional login process for the GP client, but FastPAth does too have a session timeout .. which many are not aware of.
      Beat Bucher
      Montreal QC/Canada
    DSC Communities replied 7 years, 9 months ago 1 Member · 0 Replies
The discussion ‘SQL Error after Posting Batch’ is closed to new replies.
