Soptype in SOP10106
  • Soptype in SOP10106
    Posted by Jeff Roe on May 1, 2017 at 7:08 pm
    • Jeff Roe
      May 1, 2017 at 7:08 PM
      We are seeing invoices in the SOP10106 table with a soptype of 3 and 4.
      In some cases we are see the same invoice number with a soptype of 3 and soptype of 4.
      What drives the soptype in the SOP10106 table?
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Thaddeus Suter
      May 1, 2017 at 8:30 PM
      They are not both Invoices.
      The primary key in SOP10106 is both SOPTYPE and SOPNUMBE.
      To avoid confusion on SOPNUMBE since they are not unique, use a different numbering schema for each SOPTYPE (DOCID) in your SOP Setup.
      SOPTYPE 3 = INVOICE
      SOPTYPE 4 = RETURN
      We have an “I” usually in the Invoices and an “R” in the Returns
      Thaddeus Suter
      Retus, Inc
      Helotes TX
    • David Musgrave
      May 2, 2017 at 1:36 AM
      For a full list
      1 – Quote
      2 – Order
      3 – Invoice
      4 – Return
      5 – Back Order
      6 – Fulfilment Order
      Note that Fulfilment Order is normally listed after Orders in the drop down list, so that the positions in the drop down list do not match the data in the database.
      There are Dexterity functions that convert the values for you and most windows have an extra field which can be used from VBA.
      For example the SOP_Entry window has fields SOP Type and SOP Type Database.
      David
      Managing Director
      Perth, Western Australia
      http://www.winthropdc.com
    • Jeff Roe
      May 8, 2017 at 1:15 PM
      Clearly I was not looking at the details correctly
      Jeff Roe
      Kele Inc
      Bartlett TN
    Jeff Roe replied 8 years, 10 months ago 1 Member · 0 Replies
The discussion ‘Soptype in SOP10106’ is closed to new replies.
