Smartlist Builder Table Access
  • Smartlist Builder Table Access
    Posted by sshankel@woodings.com on May 12, 2020 at 10:40 am
    • Scott Shankel
      May 12, 2020 at 10:40 AM
      Hello All,Ā
      Is there a way to limit table access within smartlist builder?Ā  (ie – I would like to give a user access to smartlist builder but would not want them to be able to see the financial and payroll tables)
      Scott
      Scott Shankel
      Woodings Industrial Corp.
      Mars PA
    • Sarah Brewster
      May 12, 2020 at 11:27 AM
      Hi , eOne provides ?instructions for configuring Table Security on their website.Ā  Hope this helps!
      Sarah Brewster
      Implementation and Support
      ActivReporter by nQativ
      Lubbock TX
    • Aref Karam
      May 12, 2020 at 11:31 AM
      Hi Scott,
      There is only one security operation under the access list in the Security Task Setup window:
      Product: SmartList Builder
      Type: SmartList Builder Permissions
      Series: SmartList Builder
      Operation: View SmartLists with SQL Tables
      However, if the user who has access to create smartlists doesn’t have permission to the Finance and Payroll modules, then they can only create the smartlists but will not be able review them and see the data.
      Aref Karam
      Data Consultant
      LTI Information Technology
      Ann Arbor MI
    • Nicole Albertson
      May 13, 2020 at 9:46 AM
      Scott,
      The table security that Sarah provided the link for is exactly what you want to look it.Ā  It was specifically designed with the payroll module in mind.Ā
      The Table Security will set SmartList Builder not to display which ever tables you mark in the Table Security window when adding tables and anywhere else in the Builder tools that you can see the lists of tables.Ā  You can add a role to the window that you want to exclude from this security if you want a few users to be able to add all tables.
      Just remember when setting it up, that any tables you check will not display in the table lists in SmartList Builder. Ā
      Nicole Albertson
      Product Manager
      eOne Solutions
    sshankel@woodings.com replied 6 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Smartlist Builder Table Access’ is closed to new replies.
