SmartList Builder
  • SmartList Builder
    Posted by Shari Bruno on January 31, 2020 at 4:47 pm
    • Shari Bruno
      January 31, 2020 at 4:47 PM
      Hello!
      I have a SmartList Builder report that is looking at Sales Line Items because I need the line details, and combining that with an Extender and Company table. Only sales invoices are on the report even though there are returns that should show up. I have tried linking into SOP SQL tables and various sales tables with no luck. Any thoughts on how to get returns on this report?
      Shari Bruno
      Accounting Operations Manager
      Bible League International
      Crete, IL
    • Sarah Brewster
      January 31, 2020 at 5:23 PM
      Does your report have any restrictions on the SOP Type?Ā  The Sales Line Items SmartList by default will show returns.Ā
      All your SOP transaction line detail (quote/order/invoice/return, etc.) should be in table SOP10200 for unposted/open years and SOP30300 for historical.Ā  The returns will show up as SOPTYPE 4.
      Sarah Brewster
      Implementation and Support
      ActivReporter by nQativ
      Lubbock TX
    • Charles Allen
      February 3, 2020 at 12:52 AM
      Do the transactions that are not invoices have Extender data? I’m wondering if there’s an Inner Join instead of an Outer Join. Try changing the join types to outer joins to see if you get more data.
      Charles Allen
      Senior Consulting Manager
      BKD LLP
      713.499.4629 Office
      713.494.2104 Cell
      ****** BKD, LLP Internet Email Confidentiality Footer ******
      Privileged/Confidential Information may be contained
      in this message. If you are not the addressee indicated in
      this message (or responsible for delivery of the message
      to such person), you may not copy or deliver this message to
      anyone. In such case, you should destroy this message, and
      notify us immediately. If you or your employer do not consent
      to Internet email messages of this kind, please advise us
      immediately. Opinions, conclusions and other information
      expressed in this message are not given or endorsed by my
      firm or employer unless otherwise indicated by an authorized
      representative independent of this message.
      Any tax advice contained in the body of this email was not
      intended or written to be used, and cannot be used, by the
      recipient for the purpose of avoiding penalties that may be
      imposed under the Internal Revenue Code or applicable state
      or local tax law provisions.
      These discussions and conclusions are based on the facts
      as stated and existing authorities as of the date of this
      email. Our advice could change as a result of changes in the
      applicable laws and regulations. We are under no obligation
      to update this information if such changes occur. Our advice
      is based on your unique facts and circumstances as you
      communicated them to us and should not be used or relied
      on by anyone else.
      ——Original Message——
      Hello!
      Shari Bruno
      Crete, IL
      February 3, 2020 at 8:25 AM
      I second , it sounds like the “joins” are set at Equals?? instead of possible “Left Outer” which means that if it is looking first at the SOP Tables it will not bring in any information that is not “Equal” to a match in the Extender Tables.
      If you are using SLB to build it try the Left Outer method.Ā Ā
      If you are not using SLB, then edit the view in SQL to use something other that a clear Left or Right Join, like use an inner join.
    • Shari Bruno
      February 3, 2020 at 1:53 PM
      Ā Ā  and anyone else who has any ideas on how to fix this.
      This is a SLB report, and all my links in SLB are always left outer.
      The Extender window I’mĀ linking toĀ is inĀ Item Maintenance, and it doesn’t matter if the item has these fields or not, I have transactions on the report that are blank for those fields.
      For the rest it’s a little too much to embed in this reply so I attached a document with screen shots and more explanation.
      This report is to come up with a yearly number that previously was done by combining figures from several different people. But all of the information lives in GP so I figured I would try to come up with a way to get it direct. Except for the returns everything else on the report works great.
      Shari Bruno
      Crete, IL
    • Charles Allen
      February 3, 2020 at 2:29 PM
      Would you display the SQL query that SmartList Builder is generating?
      Charles Allen
      Senior Consulting Manager | BKD
      2700 Post Oak Blvd. Suite 1500
      Houston, TX 77056
      713.499.4629 Direct
      713.494.2104 Mobile
      Solver Certified Badge Smaller
      on by anyone else.
      Shari Bruno
      Crete, IL
    • Shari Bruno
      February 3, 2020 at 3:58 PM
      Hi Charles,
      Here’s the
      SQL query:
      select
      * from (select * from [<<COMPANY_ID>>]..slbSalesOrderLines with (NOLOCK)) T1
      Ā LEFT JOIN (select C.Extender_Record_ID, C.[_1], isnull(B204.[BLI Reporting Type_204],0) as [BLI Reporting Type_204], isnull(B205.[BLI Product Type_205],0) as [BLI Product Type_205] from (select EXT01100.Extender_Record_ID, Extender_Key_Values_1 as [_1] from BL..EXT01100 where EXT01100.Extender_Window_ID = ‘P2I INFO’) C
      Ā left join
      (select Extender_Record_ID, TOTAL as [BLI Reporting Type_204] from [BL]..EXT01103
      Ā where Field_ID = 204) B204
      Ā on C.Extender_Record_ID = B204.Extender_Record_ID
      Ā and C.Extender_Record_ID = B204.Extender_Record_ID
      Ā left join
      (select Extender_Record_ID, TOTAL as [BLI Product Type_205] from [BL]..EXT01103
      Ā where Field_ID = 205) B205
      Ā on C.Extender_Record_ID = B205.Extender_Record_ID
      Ā and C.Extender_Record_ID = B205.Extender_Record_ID ) T2
      Ā on
      Ā T2.[_1] = T1.ITEMNMBR
      Ā LEFT JOIN [BL]..SY04200 T3 with (nolock)
      Ā on
      Ā T3.[COMMNTID] = T1.COMMNTID?
      Shari Bruno
      Crete, IL
    • Charles Allen
      February 3, 2020 at 4:49 PM
      There’s a Where Clause. Can you take out the Where Clause to see if it makes a difference?
      Charles Allen
      BKD LLP
      713.499.4629 Office
      713.494.2104 Cell
      on by anyone else.
      Hi Charles,
      Here’s the
      SQL query:
      select
      Ā left join
      Ā left join
      Ā on
      Ā on
      Shari Bruno
      Crete, IL
    • Shari Bruno
      February 4, 2020 at 3:08 PM
      There areĀ three Where clauses – I underlined and bold typed them. Should I take all ofĀ them out??
      select
      Ā left join
      Ā left join
      Ā on
      Ā on
      Ā T3.[COMMNTID] = T1.COMMNTID???
      Shari Bruno
      Crete, IL
    • Jim Harris
      February 5, 2020 at 9:48 AM
      If you remove the extender source entirely and just have the part for comments, does it then include the returns?
      Do you have any restrictions in place in SLB?
      Jim Harris
      ExamWorks, Inc.
      Atlanta GA
    • Shari Bruno
      February 5, 2020 at 11:19 AM
      There are no restrictions in place on the SLB report.
      When I remove the Extender window I get this message when I open the report in SmartView:
      ??I am also unable to add the SOP Type back onto the SmartView report, the wheel just turns.
      Shari Bruno
      Crete, IL
    • Shari Bruno
      February 5, 2020 at 3:38 PM
      I got a resolution for this from when I emailed her and asked when the next Builder Monday was happening so I could turn in this issue. Because Nicole is SUCH a rock star, and the nextĀ Builder Monday is not tackling problems,Ā she looked intoĀ it and found the problem – the restriction by Invoice Date. Some returns don’t have invoice dates and when I removed that restriction the returns showed up. To get the data we need from this reportĀ I added the Posted Date and restricted by that and all is well.
      ThanksĀ to all of you who took the time to help me figure this out, I do appreciate it.
      Shari Bruno
      Crete, IL
    Shari Bruno replied 6 years ago 1 Member · 0 Replies
The discussion ‘SmartList Builder’ is closed to new replies.
