Reprinting after Posting an AP Batch
  • Reprinting after Posting an AP Batch
    Posted by DSC Communities on December 14, 2017 at 10:22 am
    • Jolaine Bowman
      December 14, 2017 at 10:22 AM
      ?Our printer had issues this morning, can we somehow reprint the reports that usually run after we post an AP batch?
      Jolaine Bowman
      Treasury & AP Manager
      Medica
      Minneapolis MN
    • Christine Boisvert
      December 14, 2017 at 10:48 AM
      Are you referring to the posting journals? If so, you are able to reprint them under the Purchasing area, under Report -> Posting Journal. Then you can select which report you want to reprint and click New. Ensure to insert a restriction for your posting date or Batch ID, in the white box area.Ā
      reprint posting journal
      Christine Boisvert
      Floform Countertops
      Winnipeg MB
    • Shari Bruno
      December 15, 2017 at 10:55 AM
      Depending on which journal you want to reprint, there are different areas to access the reports from?. Our AP setup prints a Transaction Journal,Ā  General Ledger Distribution Journal, and a General Posting Journal. I listed the procedures below.
      • To reprint the Transaction Journal:
      • Purchasing>Reports>Posting Journals
      • Reports: Choose Transaction Journal
      • Options: If you do not have a saved report click on New toĀ bring up the Purchasing Posting Journal Options window. If you have a saved report then highlight the report name and click on Modify bring up the Purchasing Posting Journal Options window.
        • Option:Ā If creating a newĀ report type in a report name
        • Sort By:Ā ChooseĀ Batch ID from the drop down
        • Ranges: Choose Batch ID from the drop down
        • Click on the looking glass at the end of the From field to open the Historical Purchasing Batch IDs window
        • Click on the Posting Date column then scroll to the bottom to access the most recent batches.
        • Click on the batch needed and Select
        • Insert
        • Destination: For a new report click on Destination to open the Report Destination window, choose your preferred destination, and click OK.
        • Print
      • When printing is complete close the Purchasing Posting Journal Options window
      • If desired, whenĀ asked to save changes to the report option click on Save to keep the parameters entered
    • To reprint the General Ledger Distribution Journal:
    • Reports: Choose GL Distribution Detail from the drop down
    • Options: If you do not have a saved report click on New toĀ bring up the Purchasing Posting Journal Options window. If you have a saved report then highlight the report name and click on ModifyĀ to bring up the Purchasing Posting Journal Options window.
    • Options: If creating a newĀ report type in a report nameĀ
    • Sort By: Choose Batch ID from the drop down
    • Insert
    • Ā Print
    • If desired, whenĀ asked to save changes to the report option click on Save to keep the parameters entered.
    • To reprint the General Posting Journal:
    • Ā Financial> Reports>Cross-Reference
    • Ā Reports: choose Audit Trail Code from the drop down
    • Ā Options: If you do not have a saved report click on New toĀ bring up the Cross-Reference Report OptionsĀ window. If you have a saved report thenĀ highlight the report name and click on ModifyĀ to bring up the Cross-Reference ReportĀ  Options window.
    • Include: Check Posting Accounts, Unit Accounts, and Voided Transactions.
    • Sort By: Audit Trail Code
    • Year: Click on Open and choose the proper year from the drop down at the end of the Year field.
    • Ranges: Click on the drop down and choose Date.
    • From/To: choose the postingĀ date of the journal needed.
    • Insert into Restrictions
    • Go back to Ranges and click on the drop down and choose Source Document
      • Type in PMTRX in From and To, or click on the looking glass and choose that code from the Source Documents window.
    • Ā Print
    • If desired, whenĀ asked to save changes to the report option click on Save to keep the parameters entered.Ā Ā
    Shari Bruno
    Accounting Operations Manager
    Bible League International
    Crete, IL
The discussion ‘Reprinting after Posting an AP Batch’ is closed to new replies.
