  • Report
    Posted by Tracy Yaklyvich on June 10, 2020 at 1:51 pm
    • Tracy Yaklyvich, MBA
      June 10, 2020 at 1:51 PM
      ??Hi.Ā  Can someone please remind me how to run a trial balance report with non-consecutive account numbers?Ā  Thanks!
      Bethesda MD
      tyaklyvich@ashp.org
    • Gerald Buenafe
      June 10, 2020 at 3:41 PM
      Hi Tracy,
      I don’t think you can.Ā  It is always a range.
      Gerald Buenafe
      Owner/Consultant
      BTP Technologies LLC
      CHANTILLY VA
    • Barbara Gavron
      June 11, 2020 at 6:25 AM
      Will the accounts be the same all the time or will they change frequently? ?If they will stay consistent you could always create a Row Format in MR (and probably most other reporting packages that work with GP) that lists just the accounts you want to see and run one out of there. And the advantage of that would be that it can be easily exported to excel.
      If the account numbers change from instance to instance this may not be effective time-wise, but depending on the number of accounts you are querying you could make it work.
      Barbara Gavron
      904-536-0129
    • Sally Diehl
      June 11, 2020 at 7:43 AM
      Tracy ~
      I agree with Barbara’s option.Ā  One other possibility is if the accounts share a common segment other than the first segment.Ā  For example is the second segment is Department, and you wish to see all accounts from one department, then using the segment filter on the standard trial balance will produce the report.
      Sally?
      Sally Diehl
      RSM – Sr. Director, Technology Consulting
      sally.diehl@rsmus.com
      612.629.9058
      Minneapolis, MN
    • Sally Higgins
      June 11, 2020 at 9:18 AM
      Hi – what order are you trying to do them in? You can do an Excel report and put them in the order you’d like.
      Sally Higgins
      efs consulting, inc
    • Jennifer Hershberger
      June 11, 2020 at 12:37 PM
      Hi Tracy –Ā
      Your answer is Navigation List!Ā
      If you’re in the financial section, you select the Accounts Navigation List. Once it loads, check the accounts you want for your report. Then click on Reports. Select Print Trial Balance. You’ll then have the option to Include Details, and what year. When you click the Print button, you’ll have the opportunity to print to screen, printer or to a file.
      Viola! A trial balance with non-consecutive account numbers.Ā
      Enjoy!
      Software Consultant
      QCI
      Johnston IA
      June 12, 2020 at 11:48 AM
      that’s it Jennifer!Ā  Thanks so much.Ā  ?
      Bethesda MD
      tyaklyvich@ashp.org
    Tracy Yaklyvich replied 6 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Report’ is closed to new replies.
