Purchasing Vendor Combiner/Modifier
  • Purchasing Vendor Combiner/Modifier
    Posted by csexton@nbs.com on January 17, 2022 at 12:23 pm
    • Charlotte Sexton
      January 17, 2022 at 12:23 PM
      I am trying to use the Purchasing vendor/Combiner and once I click the process button I receive the following error message:
      We attempted using sa to see if it was a security setting but same results. We are on GP 2018 (18.00.0672 R2)..Ā
      Thank you,
      Charlotte SextonĀ
      NBSĀ
      Accounting Operations Manager
      Charlotte Sexton
      Nation’s Best Sports
      Fort Worth TX
    • Aref Karam
      January 17, 2022 at 3:25 PM
      Does this happen to all vendors or just this one? Did you try that in a test company/environment?
      Do you have third party modules added to GP? Like Mekorma’s Remote Payment Workflow?
      If so, there’s maybe a pending item in a workflow for this vendor that needs to be completed/deleted, before you can run the Vendor Combiner Utility.
      Aref Karam
      Data Consultant
      LTI Information Technology
      Ann Arbor MI
    • Charlotte Sexton
      January 17, 2022 at 3:49 PM
      . I haven’t attempted with any other vendors but could it be because there are open PO’s for the vendor that I want to move from? PO’s were set up under the incorrect vendor ID (but it is in fact a duplication of the other vendor). Is there an easier way to accomplish this?
      We do have third party modules. Mekorma is one but not the remote payment workflow.
      My other thought was to set up new PO’s under the correct vendor ID and then cancel the remaining under the incorrect vendor and then make it inactive.
      Charlotte
      Charlotte Sexton
      Fort Worth TX
    • Blair Christensen
      January 18, 2022 at 9:49 AM
      One thing I’ve noticed about the Combiner/Modifier tools is that they look for ANY column in ANY table in the schema with that column name and attempt to alter the value regardless if it is a Dynamics GP table or not.Ā  We had some custom stuff we were using where we ran into a similar issue as yours – the tool failed because of key constraint errors on our custom stuff.
      What I would suggest is to find the offending key’s table and look at the data.Ā  You can use this to get the table:
      SELECT COLUMN_NAME
           , TABLE_SCHEMA
           , TABLE_NAME
        FROM INFORMATION_SCHEMA.KEY_COLUMN_USAGE
       WHERE OBJECTPROPERTY(OBJECT_ID(CONSTRAINT_SCHEMA + '.' + QUOTENAME(CONSTRAINT_NAME)), 'IsPrimaryKey') = 1
         AND CONSTRAINT_NAME LIKE 'MEEP%'?
      The error is saying that there is already data in the table with values ‘3329’,” which is why the modify is failing.Ā  This is likely old/garbage data which can be removed.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      GPUG All-Star
    • Charlotte Sexton
      January 19, 2022 at 12:18 PM
      Thank you for the information. Our IT used the script and cleared the table values and it worked like a charm. Everything moved as expected. Appreciate the help.Ā
      Charlotte
      Charlotte Sexton
      Fort Worth TX
    csexton@nbs.com replied 3 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Purchasing Vendor Combiner/Modifier’ is closed to new replies.
