Payroll Year-End Close
  • Payroll Year-End Close
    Posted by Ashton Blocker on January 13, 2021 at 3:49 pm
    • Ashton Blocker
      January 13, 2021 at 3:49 PM
      #HRandPayroll #YearEnd
      It looks like I made a boneheaded mistake by not refreshing my memory on the Payroll Year-End Close procedures before I applied the 2021 Tax Update.Ā Ā
      KB -Year-end closing procedures for Microsoft Dynamics GP Payroll
      As you can probably already guess, I neglected to create the Year-End file before applying the 2021 Tax Update.Ā
      Is there anything I should be on the lookout for as we tackle the task of generating W-2s as a result of this oversight?Ā  Is there a workaround without restoring to a backup prior to the install of the Tax Update, which would result in a ton of re-work?Ā  Or, are there published instructions/procedures for situations like this?
      I seem to remember something about resetting the system date to a date in the prior year can help on some issue like this, but am not sure it pertains to this situation.
      We generate about 30-40 W-2s in our organization.
      Ashton Blocker
      Joint Municipal Water and Sewer Commission
      Lexington, SC
    • John Kirsch
      January 14, 2021 at 6:11 PM
      Hi Ashton,
      You can roll back the tax tables.Ā  If you use the below link and log into Customer Source, you should be able to download and apply the 2020 tax tables from the CAB file.Ā  It requires the use of SQL so if you are not familiar I’d suggest working with your IT or partner for assistance.
      https://mbs.microsoft.com/customersource/northamerica/GP/downloads/tax-regulatory-updates/tugp2018
      John Kirsch
      GP Product Lead
      Global Optics Inc.
      Green Bay WI
    • Ashton Blocker
      January 15, 2021 at 11:18 AM
      John,
      Thanks for your suggestion.Ā  I’ve reached out to our GP partner to help walk us through the steps we need to take, as making edits in SQL isn’t something I think we’re comfortable with quite yet in our Finance Department.Ā  It’s comforting to hear that there is an ability to “roll back” the tax tables in order to get the Year-End Wage File & W-2s printed.
      Ashton Blocker
      Lexington
    Ashton Blocker replied 5 years, 10 months ago 1 Member · 0 Replies
The discussion ‘Payroll Year-End Close’ is closed to new replies.
