Order notes not clearing
  • Order notes not clearing
    Posted by Jeff Roe on June 14, 2017 at 9:57 am
    • Jeff Roe
      June 14, 2017 at 9:57 AM
      We have noticed that when a new order/quote is entered there is already an order note from a previous order/quote that appears.
      Why would an order/quote note show on subsequent transactions?
      We are running in a 4 server Terminal Server configuration.
      Ideas?
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Thaddeus Suter
      June 15, 2017 at 5:29 PM
      This occurs when somebody has screwed up the NOTEINDX in the Company Master Table (SY01500) or it has no room for growth.
      A new SO is created and it gets the next NOTEINDX from Company Master that has already been used. Hence a used Note shows up on the SO when it should not.
      The fix is to run a sysobjects table cursor select on NOTEINDX to get the MAX(NOTEINDX) from the transaction tables.
      One you find the max NOTEINDX, update your company master table NOTEINDX to any value that is larger – but make sure you leave room for growth like an extra 0 or 00.
      Alternatively, go look at what the NOTEINDX is in the Company Master table and double its value while leaving room for growth. That will solve the problem…just less precisely than finding the MAX Noteindex from the transaction tables.
      Thaddeus Suter
      Retus, Inc
      Helotes TX
    Jeff Roe replied 8 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Order notes not clearing’ is closed to new replies.
