Next Journal Entry number jumping
  • Next Journal Entry number jumping
    Posted by David Morinello@mttsvc.com on October 7, 2025 at 4:14 pm
    Does anyone have a solution similar the PSTL PO numbering fix?
    Next purchase order number jumping or wrong
    We have implemented Wipfli ExpenseConnect and have started seeing Journal Entry numbers jump back to 5-digit numbers, then back to 7-digit numbers again. We have other processes generating JE numbers and all are staying a 7-digits except for the ExpenseConnect generated ones.
    Symptoms aside, Wipfli says it is in GP settings. So, I am hoping I can adapt a variation on the PSTL PO solution into a JE version and lock these down.
    Dynamics GP 18.3
    David Morinello@mttsvc.com replied 5 months, 2 weeks ago 3 Members · 5 Replies
  • 5 Replies
  • Deborah A Bergman
    October 7, 2025 at 4:25 pm
    Is it the PO number or the next GL number? The next GL number is set in the GL setup.
    • David Morinello@mttsvc.com
      October 8, 2025 at 12:59 pm
      Yes, the issue is with jumping JE numbers. It is set correctly (7 digits) in the GL40000 Table. 1187586 is the next at this moment.
      Some, not all Wipfli ExpenseConnect processed records jump back to JEs in the 12445 to 12669 (so far) range.
  • David david@winthropdc.com
    October 7, 2025 at 9:46 pm
    Hi David
    We would be able to use GP Power Tools to debug this and find out when the next GL Journal number is being returned and is less than the previous value.
    We can then add a trigger to prevent that from happening.
    Kind regards
    David
      October 8, 2025 at 1:04 pm
      Thanks David!
      If I can narrow enough of the issue to reproduce it, then I will try a trace.
      Wipfli ExpenseConnect, I believe, makes eConnect calls as part of their processing.
    October 15, 2025 at 8:48 am
    This turned out to be a mapping and value transformation issue with Wipfli ExpenseConnect. We are in the process of fixing the configuration with the help of Wipfli Support.
    We have this implemented in multiple GP companies and ExpenseConnect was incorrectly selecting one of the other companies and using the next available Journal number from that smaller company.
