I can’t figure out why I’m sometimes getting plus signs after the account numbers when I use a column type of ACCT in MR 2012.Ā I’ve checked the row and column settings, and drilled down to see the data under the row.Ā I’ve also searched thru the MR documentation unsuccessfully.
All these rows are linked to single GL accounts using both account segments.Ā None are ranges of accounts.
Any ideas?
—————————— Don McCready Retired Controller and IT Director The Schaefer Group, Inc. Beavercreek OH ——————————
Windi Epperson
April 13, 2020 at 11:55 AM
Is this how it shows in the row format or how it actually prints on the report? Thanks Windi ?
—————————— Windi Epperson Customer Support Manager Njevity, Inc norman OK 720-870-9700 x104 —————————— ——————————————-
, I would bet that the answer lies in the Row Definition the report is using.Ā I was able to duplicate this behavior by adding references to empty Account segments as shown in the screenshot below.
—————————— Sarah Brewster Implementation and Support ActivReporter by nQativ Lubbock TX —————————— ——————————————-
Thanks for the suggestion.Ā I looked at my row definitions and the links all looked okay… only one line showing both account segments and nothing showing in any other lines (attached).Ā So I created a new row definition from scratch with the same (apparent) settings.Ā That solved the problem.Ā No more plus signs on the report.
So I can only surmise that there may have been some unseen values in other lines in some of the row definitions.
Thanks again.
—————————— Don McCready Retired Controller and IT Director The Schaefer Group, Inc. Beavercreek OH —————————— ——————————————-
