Modify Reports
  • Modify Reports
    Posted by MARY MALLAZZO on January 22, 2021 at 2:48 pm
    • Mary Mallazzo
      January 22, 2021 at 2:48 PM
      Hello
      What is the best practice to modify reports in GP, without having to do it off hours?
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Matthew Arp
      January 22, 2021 at 2:51 PM
      Depends on the environment, are you making the changes in a Terminal Server environment(shared) or is GP deployed to each user’s desktop? We use Terminal Servers and I will generally customize the report on my local instance of GP and then either export the report and import on the terminal servers or just copy the modified report dictionary that contains the modified report.
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • Mary Mallazzo
      January 22, 2021 at 3:00 PM
      We are currently running with GP deployed on each users desktop with a shared dictionary.Ā Ā
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Matthew Arp
      January 22, 2021 at 3:07 PM
      I’d recommend running your local workstation without the shared dictionary, then you can copy your local updated dictionary to the network share for users to get. Are you encountering any specific issues?
      Matthew Arp
      Hunton Group
      Houston TX
    • Mary Mallazzo
      January 22, 2021 at 3:19 PM
      How do I do that?
      How do I change GP to point to a dictionary on my local machine?
      If I then want to copy the updated dictionary to the server, does it need to be done when no one is using GP?
      Or would it be better to export/import the changed report?
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Matthew Arp
      January 22, 2021 at 3:34 PM
      If you examine your DYNAMICS.SET file, you should see that your FORMS & REPORTS dictionaries are pointed to your shared network location. (Its best practice to have the unmodified PRODUCT dictionary files stored locally). So you’d simply edit your DYNAMICS.set to point to your local GP installation folder and then be sure to copy those files into your GP installation folder. You could then make the modifications on your local machine, test, etc. Then when you’re ready copy the relevant modified dictionary file to the shared network location. The official answer would be to use the import/export feature in GP, but honestly I usually just copy the dictionary file.
      Matthew Arp
      Hunton Group
      Houston TX
    • David Musgrave
      January 25, 2021 at 2:00 AM
      I agree with .
      I actually recommend against using network shared custom dictionaries as it causes performance issues and is prone to dictionary corruption.Ā  Please see my articles from 2008 explain the issues and providing alternate solutions. These have been described as the Musgravion Principles. ??
      https://winthropdc.wordpress.com/2008/08/20/automating-distribution-of-customizations-part-1/
      https://winthropdc.wordpress.com/2008/08/26/automating-distribution-of-customizations-part-2/
      I recommend always working on a local copy of custom reports and forms until you have it working as desired. Then it can be deployed once completed using Customization Maintenance (while users are still logged in). Or you can copy the file manually, or automatically from an update area as per my articles.
      Regards
      David
      Managing Director
      Perth, Western Australia
      http://www.winthropdc.com
    • David Musgrave
      January 25, 2021 at 2:02 AM
      PS: I believe that if you are editing a report in shared reports.dic and another user prints the same report that is when the reports dictionary can be corrupted.
      Managing Director
    • Scott Davis
      January 25, 2021 at 8:28 AM
      Along with the methods outlined by Matt and David, I’ve previously used a method where all your modified forms and reports are deployed via .bat file. It takes a bit more time to set up and involves some training of users, but keeps everything exactly the same and makes change deployment easy.
      Once you’re happy with a unified set of Forms and Reports in your .dic and .vba files, you create a .bat file that copies all the explicit .dic and .vba files out of your local GP installation and places them in a shared drive on your network (ie. \ServerNameGPSharedGPReports). Access to this file should only be given to users who are allowed to make changes to the organizations reports and who have been trained on how to use it.
      Then you create a second .bat file that does 2 primary things:
      1. Copy all the .dic and .vba files from your shared location to the local installation.
      2. Launch GP.
      Then you deploy a shortcut to the second .bat file to all user workstations and instruct users to always use that shortcut. This guarantees that every time they open GP they will have the latest version of modified forms and reports, and if you want to make changes, you make them on your local machine and push them up to the server, then the next time each user opens GP with their local .bat file they get the latest version. You can also modify the shortcut to use the GP icon if it helps users remember what it’s there for.
      This method is my personal favourite, but I’m also biased as it’s the first one I learned and have customized it to add automatic backups of .dic and .vba files with a time and date stamp in case things go haywire and you can always revert back.
      Scott Davis
      Trudell Medical Limited
      London ON
    • David Musgrave
      January 25, 2021 at 8:34 AM
      If you look at my articles, it uses both a batch file and xcopy to only copy new and changed files and also runs the batch file during the login script.
      The batch file can be used manually on Terminal servers when no one is logged in. All workstations can either run the batch file or just logout and login.
      Regards
      David?
      Managing Director
    MARY MALLAZZO replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Modify Reports’ is closed to new replies.
