Modify a Word Template
  • Modify a Word Template
    Posted by MARY MALLAZZO on May 24, 2017 at 12:59 pm
    • Mary Mallazzo
      May 24, 2017 at 12:59 PM
      Hello
      We are using the Word template to print A/P Check Remittance.Ā  I created a new template based on the original, made changes to the new one, assigned it to the company, but it is still printing the original template.Ā
      What am I missing?
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Silver Subie
      May 24, 2017 at 2:04 PM
      It sounds like you have not set up the new one as Default under Company Assignment window——————————————-
    • Mary Mallazzo
      May 24, 2017 at 2:51 PM
      I do have the modified version assigned to the company …..see attached, and I also unchecked the original version
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Diana Doane
      May 24, 2017 at 3:01 PM
      There are many things with Word Templates that could be the culprit.Ā  But let’s start with a basic…..Did you update GP Security to use the modified report rather than the standard?
      Diana Doane
      Ascend Learning, LLC
      Leawood KS
    • Mary Mallazzo
      May 24, 2017 at 3:37 PM
      Are you referring to the Alternate/Modified Forms and Report Screen?
      If so, oddly enough I do not see it listed…..maybe that is the issue?
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Diana Doane
      May 24, 2017 at 6:57 PM
      Yes, the Alternate/Modified Forms andĀ Reports areaĀ is what I’m referring.Ā  Depending on your security, you may need to verify which ID you need to update (if you have more than 1 ID)
      From your description of steps to create the word template, you may have missed the portion where you create the modified report (which then shows up in the security).Ā  This link to Leslie Vail’s outline for word templates should help find other pieces toĀ creating a word templateĀ you may need as well.Ā  As she states, Word Templates are tricky.Ā  Let us know if we can assist further.
      Quick and Dirty Checklist for Modifying Word Templates
      Dynamicsconfessions remove preview
      I was asked recently for the basic steps on how to modify Word templates. They didn’t need step-by-step instructions, just something to help them along the way. Here’s the list I came up with. I’m sure something is missing, I trust you will correct me where I’m wrong.
      View this on Dynamicsconfessions >
      Diana Doane
      Leawood KS
    • Mary Mallazzo
      May 26, 2017 at 11:36 AM
      Thank you!
      This is exactly what I needed.
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    MARY MALLAZZO replied 9 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Modify a Word Template’ is closed to new replies.
