Microsoft Outlook Pop-Up for sending email messages from GP 2018
Posted by DSC Communities on September 19, 2019 at 10:13 am-
Erin White, APPM
MemberSeptember 19, 2019 at 10:13 AM
Hi All,We are in GP 2018 and attempting to use the vendor email remittance for EFT payments. We’ve got everything working as it should be but have an Outlook issue. For each email being sent we have to click “Allow” in the pop-up window copied below. Needless to say, we need to stop that from happening.
We have found several articles talking about how to turn the pop-up off. None of the solutions have worked for us because we have GP & Outlook installed on a terminal server (we log in remotely), and it appears Outlook is unable to validate our antivirus software because of that. We’re assuming this is why we can’t turn off the pop-up window.——————————
Erin White, APS
Accountant – Accounts Payable
Multi Service Technology Solutions, Inc
Overland Park, KS
Following-
We have the same issue.——————————
Laura Duffey
Senior Staff Accountant
New Management Services
Jacksonville FL
Bob O’Malley
MemberSeptember 20, 2019 at 9:49 AM
A quick google search returned the below article – not sure if your local IT or partner can assist with a workaround.——————————
Bob O’Malley
Lead, Business Analyst
Stanley Healthcare
Waltham MA
Hi Erin,
I just worked through this issue last week for a Customer.Our issue was that the Customers GP Server was not on the same domain as the Exchange Server.so it would not allow email to pass through to exchange because it was not set to send mails to external receivers.
Use the DNS-Record: mail.customer-group.com and Port 25
No authentication required.To fix it we had to configure the GP server for SMTP email with the correct DNS-Record: mail.customername-group.com and Port 25
In GP you set the email preference under System Preferences to EXCHANGE.Once that was done, the Exchange Log On box popped up in GP as expected and email worked like a charm.
Good luck!
Sue——————————
Susan Gamache
GraVoc
Peabody MA
Erin White-Terrell
MemberOctober 2, 2019 at 7:20 AM
Thanks Susan.——————————
Erin White-Terrell
Information Systems Manager
Messe Frankfurt Inc.
Atlanta
Chase Landorf
MemberSeptember 23, 2019 at 7:52 AM
We had this issue with sending email as well. I ended up buying a server software called Click Yes Pro. It needed to be installed on the admin credentials, then ran to gather the outlook data. Once done, it is left on, and then forget.——————————
Chase Landorf
Director of I.T.
Ideal Deals, LLC dba Ideal Aluminum Products
Saint Augustine FL
Erin White, APPM
MemberSeptember 24, 2019 at 9:06 AM
Thanks all for the great suggestions!! We were able to resolve the issue with our IT group. IT broke down for me what their resolution was – here you go in case someone else needs another solution. Thanks again!!______
Here is the link that kind of pointed me in the right direction:
https://www.slipstick.com/developer/change-programmatic-access-options/
If you are running it on your local machine, that should cover you. If you are running on a terminal server, the following comes in handy as well.
The trick was getting it installed on each users profile, if running it on a terminal server, because those keys have to be entered while logged in as the user. For that I created a powershell script, that I got the start from here:
http://www.checkyourlogs.net/?p=24811
I just plugged in the Outlook settings and ran the script as administrator on each terminal server. The only thing you might need also is knowing which version of Office you are running, that could change the location for the registry keys. This article helped determine the location depending on your version:
Erin White, APPM
Overland Park, KS
DSC Communities replied 5 years, 5 months ago 1 Member · 0 Replies -
The discussion ‘Microsoft Outlook Pop-Up for sending email messages from GP 2018’ is closed to new replies.
