Mass Vendor Updates
Mass Vendor Updates
Posted by DSC Communities on January 3, 2018 at 1:44 pm-
Courtney Allen
MemberJanuary 3, 2018 at 1:44 PM
Is there any way to use the smart list import to do a mass update on vendors? We’d like to inactivate a lot and for those we keep active add payment terms. We’d rather not touch the sql if possible & we really don’t want to do them one by one.Thanks,
Courtney——————————
Courtney Allen
Behavioral Health Services North, Inc.
Plattsburgh NY
Charles Allen
MemberJanuary 4, 2018 at 1:01 AM
?SmartList is only a reporting tool. What you’d want to do is export the data to Excel and then enter the updated information in the appropriate columns. You would then use Integration Manager to update the vendor data.——————————
Charles Allen
Senior Managing Consultant
BKD Technologies
Houston, TX
Sally Diehl
MemberJanuary 4, 2018 at 8:54 AM
?Courtney~This can be accomplished with a SmartConnect integration. If you don’t own SmartConnect, a Macro could be utilized to update the data as well.
Good Luck!
Sally
Sally Diehl
Director Technology and Management Consulting
RSM US LLP
612.629.9058
Minneapolis MN
?If you can use your smartlist to export the following, you can turn that into an integration source document to do just exactly what you describe:
Vendor ID (required)
Vendor Name (required)
Status (you’ll have to convert these to Active=1, Inactive = 2)
Payment Terms ID (not the decription)If you aren’t familiar with integrations and would like further assistance, I’d be happy to help.
Blair Christensen
Database Administrator
Oppenheimer Companies, Inc.
Boise ID
Courtney Allen
MemberJanuary 5, 2018 at 3:22 PM
Thank you very much! This is a project we will be working on in coming months. Would you mind if I contact you when we get closer to being ready?!Courtney
Courtney Allen
Plattsburgh NY
Mahmood M. AlSaadi
MemberJanuary 6, 2018 at 2:35 PM
Smart list is a reporting tool, but I definitely believe that it can “indirectly” be the source for data correction.
Here is the proposed solution,
– You can create refreshable excel sheets which are connected to Dynamics GP, vendors smart lists ( for instance ) in order to retrieve data on the fly
– On the excel file itself, you can create Excel-based macro file in order to read the same excel data, and create a macro code accordingly.
– The macro file can be generated from the excel file, and run on Dynamics GP in order to correct/ update the same data source ( vendor list ) for instance.
We have followed the same approach with one of our clients which were aiming to correct their customer base. Refreshable excel with Excel-based macro generators worked perfectly for them
Please never hesitate to share any further inquiries or concerns
Mahmood M. AlSaadi – MVP
Principal Dynamics ERP Consultant
SIROCo LLC – (844) 708-0008
McKinney TX
m.saadi@sirocollc.com
http://www.sirocotech.com
DSC Communities replied 6 years, 5 months ago 1 Member · 0 Replies -
The discussion ‘Mass Vendor Updates’ is closed to new replies.
