Is there a way to format columns with shading or borders? I am trying to make some columns on a report stand out. Any suggestions would be greatly appreciated. Thanks, Tracy
—————————— Tracy Yaklyvich, MBA Assistant Controller ASHP Bethesda MD ——————————
Steve Burney
December 16, 2016 at 9:39 AM
Hello Tracy,
In your Management Reporter Column Definitions area you can select the column and then choose the Fill Color option to add some background to your report.
Steve
—————————— Steve Burney Senior Financial Systems Administrator Correct Care Solutions Nashville, TN United States sburney@correctcaresolutions.com 615-312-7272 Twitter @SteveBurney ————————————————————————-
You can format the Column Definition just like you would in Excel. In the screen shot below, I selected the whole column, and clicked on the ‘Fill Color’ button. In the definition, only the top ‘cells’ of that column will actually be highlighted, but once you run the report the whole column will be highlighted. If this toolbar isn’t visible, just go to View > Toolbars > Formatting
Hope this helps!
Happy shading!
—————————— Frank Heslin Financial Systems Administrator ExamWorks, Inc. Atlanta GA
*** Help Us, Help You…provide enough info so that we don’t have to ask for more:) *** *** If you solve your issue please share the solution to assist others! *** ————————————————————————-
You can add borders/boxes around report columns using the BXB and BXC Format Codes in the Row Definitions. Specify specific columns from the Column Definition in the Column Restrictions column.
—————————— Noah Moseley, Senior Consultant at the MSX Group Noah.Moseley@MSXGroup.com Email me if you need training or consulting services for Management Reporter, Forecaster or FRx.
Also, see our new Prospero offering for GP – Your new replacement for Management Reporter and Forecaster – Financial Reporting and Budgeting, all in one application. http://www.msxgroup.com/ProsperoGP ————————————————————————-
