Management Reporter – Extender and/or SQL Views
  • Management Reporter – Extender and/or SQL Views
    Posted by Kyle Malone on August 29, 2017 at 3:19 pm
    • Kyle Malone, CPA
      August 29, 2017 at 3:19 PM
      Is there anyway to pull either Extender fields or OLE Notes fields using Management Reporter?
      We have additional detail from out A/P automation system that we’d like to pass into GP (in either Extender or transaction-level OLE notes fields) & then use Management Reporter transaction level detail to pull into P&L reports.
      My thinking is that if there were a way to pull SQL tables/views using MR, this would be the best approach.
      Thoughts? Experiences?
      Thanks all,
      Kyle
      Kyle Malone
      Dynamics GP Administrator
      CGB Enterprisese, Inc.
      Covington LA
    • Andrew Collins
      August 30, 2017 at 8:15 AM
      Kyle,
      I would look into getting this information using something other than Management Reporter. Ā If you are using Extender you could look at SmartList Builder, also from eOne Solutions. Ā Or you could likely use SSRS Reports to accomplish what you are looking for.
      Management Reporter has specific table structures, especially since they have started using the Data Mart.
      Andrew Collins
      Senior Consultant
      Socius
      Atlanta, GA
    • Nicole Albertson
      August 30, 2017 at 9:14 AM
      Kyle,
      From what we know of Management Reporter, there isn’t a way to pull in any table/view that you would like from your databases.Ā  It is a predefined list of data that you can access.Ā  Because of this, you cannot pull in outside data like Extender.
      You can easily create SQL Views in Extender and pull them into other applications such as SQL Reporting Services, Crystal Reports, etc.Ā  You can also link to any Extender Window/Form that you create automatically in SmartList Builder (from eOne as mentioned) if having the “report” in SmartList, Excel, or as a Navigation List works for you.
      Nicole
      Nicole Albertson
      Product Specialist
      eOne Solutions
      Fargo ND
    • James Hummer
      August 31, 2017 at 7:36 AM
      ?We have a number of customers that do that function in BI360.Ā Ā Ā  You can make a custom view and then customization into BI360 and use Custom Drilldown to few the data in a CPM report.
      Jim Hummer
      Consultant
      Solver
      Los Angeles CA
    Kyle Malone replied 9 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Management Reporter – Extender and/or SQL Views’ is closed to new replies.
