Management Reporter Budget Totaling Problem
  • Management Reporter Budget Totaling Problem
    Posted by DSC Communities on January 24, 2017 at 9:14 am
    • Tom Clare
      January 24, 2017 at 9:14 AM
      We are using Management Reporter 2012 ver: 2.1.9001.11. I have loaded a 2017 budget into GP (using the wizard) & have set up an Actual versus Budget report in MR. The report is working fine except the budget totals are incorrect (doubled) only when the Actual number is Zero.
      Any help would be appreciated.
      Tom Clare
      CFO
      Industrial Air Centers
      Jeffersonville IN
    • Noah Moseley
      January 24, 2017 at 9:39 AM
      Hi Tom.
      Management Reporter currently has version 2.12.15000.56 which may fix the budget problem. Another possibility is that the report is written incorrectly. I would try writing another budget report without actuals and see if it has problems and then add an actuals column to this new report and see if the problem comes up again. This might help you determine if the problem is related to how the first report is written. I am available if you would like me to log in with you and look it over.
      Noah Moseley, Senior Consultant at the MSX Group
      Noah.Moseley@MSXGroup.com
      Email me if you need training or consulting services for Management Reporter, Forecaster or FRx.
      Management Reporter and Forecaster User Forums are March 14th and 15th http://www.msxgroup.com/user-forums
      Also, see our new Prospero offering for GP – Your new replacement for Management Reporter and Forecaster – Financial Reporting and Budgeting, all in one application.
      http://www.msxgroup.com/ProsperoGP
The discussion ‘Management Reporter Budget Totaling Problem’ is closed to new replies.
