Login Form DataSource Name
  • Login Form DataSource Name
    Posted by marp@huntongroup.com on March 13, 2018 at 12:02 pm
    • Matthew Arp
      March 13, 2018 at 12:02 PM
      I’m trying to figure out how to get the name of the DataSource (Server) that is selected on the the Login form. I’m trying to do this before the user has logged into the system so Globals.SqlDataSourceName is not set yet. I can get the value as a SingleSelectList index, but can’t figure out how to turn that into the string representation of the DataSource name.
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • Joshua Pelkola
      March 13, 2018 at 12:11 PM
      This is in the Registry:
      hkey_local_machine > software > wow6432node > odbc > odbc.ini
      All the connections are listed by name. There is a value stored for the SQL instance under the name “Server”
      Joshua Pelkola
      Managing Consultant
      BKD Technologies
      San Antonio TX
    • David Musgrave
      March 14, 2018 at 2:41 AM
      What’s the big picture? What language are you using?
      There is a call made by GP to populate the Datasource Drop Down List.
      I could look in the source code to see how that is done.
      David??
      Managing Director
      Perth, Western Australia
      http://www.winthropdc.com
    • Matthew Arp
      March 14, 2018 at 8:48 AM
      the end goal is I am using the the AlterLogin?? function on the EnterUserNames form to sync passwords between various GP environments. This function appears to require the DataSource name as the first parameter. I am using .NET with some injected SANScript. After recommended referencing the ODBC config, I just used a .NET wrapper to odbc32.dll? to iterate over the data sources. This does appear to work, but I’m still curious if there was a easier way to translate the selected DataSource index to the text that’s actually displayed in the UI.
      Matthew Arp
      Hunton Group
      Houston TX
    • David Musgrave
      March 15, 2018 at 2:37 AM
      If you want to get the text of a List field in Dynamics use can use the Dexterity sanScript command itemname(<Field>, <Position>).
      Is that what you were looking for?
      David
      Managing Director
    marp@huntongroup.com replied 8 years ago 1 Member · 0 Replies
The discussion ‘Login Form DataSource Name’ is closed to new replies.
